View Full Version : General Question about NOS
NOPISTONS
02-23-06, 01:20 AM
Anybody running it? And how much you running appreciate the info.
CVP33
02-23-06, 01:29 AM
I recall two members. TXsilver and Parker TX. I believe TXsilver was 100 dry and Parker TX was 150 wet. Parker used TNT.
CRZY747
02-23-06, 08:45 AM
100 shot dry, NX kit.
Only other mods are Volant intake, on motor it was 338rwhp. With the 100shot of gas it was 468rwhp.
silver05v
02-23-06, 10:10 AM
I just finished an NX NXL direct port kit on my car, I will be posting dyno figures soon. Currently set to a 120 shot. Looking to make at least 470 rwhp. By the way I recommend a window switch and fuel pressure safety switch. As long as you keep the bottle pressure where it should be and don't spray at low RPM you'll be OK. My brother happens to have an 04 GTO spraying a 150 shot for over a year now, probably over 30 bottle refills with no problems whatsoever.:thumbsup:
Barak
02-23-06, 11:53 AM
A fuel pressure switch is false peace of mind. Fuel volume can decrease with no change in pressure. An a/f ratio switch is a much better option.
Parker
02-23-06, 12:20 PM
I have been spraying a 175 before the rear gave out off the spray. I would run the fuel pressure switch and the window switch and wouldn't spray under 3500k. BTW, im faster than TxSilver!:bouncy:
Parker
02-23-06, 12:21 PM
I ran a NX kit as well.
haveboost
02-23-06, 02:42 PM
I'm also using a wet system. Will be spraying 160 single fogger. Right now only 75shot. (did not have the right jets when we did it)
I also use the msd window switch. I will be taking the car to diablosport for a custom nos tune. That's when I'll put on the 160 shot.
Hopefuly next week. Too much work, no time.
NOPISTONS
02-23-06, 02:54 PM
I am getting a dyno tune next week for NOS getting rid of torque management and improving throttle response. I plan on running 125-150 shot just woundering what wet system you guys would recommend. The tuner will set - timing at wide open throttle just woundering if i will notice a difference when running on the motor total of 4 degrees.
Barak
02-23-06, 02:55 PM
Were you able to get the diff replaced under warranty?
CRZY747
02-23-06, 03:35 PM
Don't think so, from what I know, this is his first one to go. He is the one getting the Madman rear put in first, as I understand it.
verbs
02-23-06, 04:09 PM
NOS=ricer speak :tisk:
haveboost
02-23-06, 05:30 PM
NOS can be your best friend. All you have to do is respect it and use with caution. I've had NOS for years on many different cars. Never an issue!
Some people don't know what they're doing and they run into issues. I always dyno tune the car with a wide band 02 sensor. And to be safe leave it on the rich side.
Take care,
D.F.
TXSilverV
02-24-06, 10:20 AM
I love it when guys get on here and talk trash about NOS like only rice cars use it. Have you every been to a drag strip? you will see all kinds of cars use NOS with no problems. There is a guy in Dallas that has it on a twin turbo Porsche and has been thru over 20 tanks of NOS with not one problem.
Parker first off I'm faster than you since you have no rear end in your car. When you get it fixed then maybe you will be faster but I'm better looking and drive better than you!
Parker
02-24-06, 02:13 PM
You still have stock wheels!
1.Blacks the color
2.Mines lower
3.CCWs w/ 305s
:thumbsup:
Barak
02-24-06, 04:36 PM
But the guys at the strip don't refer to it as "N-O-S" or "nawwwwwwssssss."
Luna.
02-24-06, 04:58 PM
:histeric:
ILoveMyV
02-24-06, 05:05 PM
Hey,
What is a good price for a 100 wet shot of nitrous installed in a V go for?
-Ryan
Barak
02-24-06, 07:00 PM
Off the top of my head, I'll charge you @ $750. But why only do 100 shot if you are going wet. I'd step it up to 150.
barry007
02-24-06, 07:38 PM
want to be as fast as parker...so I am really thinking of a 150 wet system. a friend with a ws6 ta has gone through like sixty bottles.with no issue.
my question is where did you go through the firewall to get into the cabin?
thanks for the advice.
B
