View Full Version : Torque Specs for V - need them
rgd
02-17-06, 09:46 PM
I have googled, searched etc the FAQ with zero luck.
Anybody know where I can find the torque specs for the rear diff.
02-17-06, 09:58 PM
This should be what you are looking for;
Differential Housing Cover Bolt
21 lb ft
Differential Ring Gear Bolt
136 lb ft
Differential Support Bolt
129 lb ft
Drain/Fill Plug
29 lb ft
Pinion Cage Bolt
21 lb ft
Pinion Flange Nut
210 lb ft
Propeller Shaft Coupler-to-Differential Flange Bolt
63 lb ft
V-SATX
02-17-06, 10:13 PM
What would we do without James?:thumbsup:
02-17-06, 10:16 PM
I'm sure you would be fine...
rgd
02-20-06, 01:31 AM
Sorry for the delay in thanking you.
So thank you very much!!:thumbsup:
21 lb ft
136 lb ft
129 lb ft
Drain/Fill Plug
29 lb ft
Pinion Cage Bolt
21 lb ft
Pinion Flange Nut
210 lb ft
63 lb ft
02-20-06, 07:27 AM
So thank you very much!!:thumbsup:You're welcome... Glad to help out...
