: Tech Manual
Tommy Deville
02-17-06, 04:30 AM
Ok.............so I wanna know whats the best manual I can get, Id like to get the one that GM techs use. which r the best? I only want the best, First and foremost I need to change some data on the pcm/Ipc and I dont wanna F it up. thnx
turbojimmy
02-17-06, 06:57 AM
The factory service manuals are not going to tell you how to 'change data' on the PCM or IPC. They explain how to replace them and will give you pin-outs for each wire that goes into them, but they won't tell you how to modify them. I don't think there is such a manual, at least from GM.
Jim
parts68
02-17-06, 09:15 AM
Break the code(hack)
that will keep you busy for awhile.
do you want printed or electronic version of
factory service manuals.
Ranger
02-17-06, 01:45 PM
The ONLY manual to get is the FSM from http://www.helminc.com. You may find a used one on ebay. Chilton & Haynes make good bird cage liners.
Tommy Deville
02-17-06, 04:28 PM
Id rather a printed, but an electronic one would be good
eldorado1
02-17-06, 04:54 PM
Tell me more of this "God Bird"... :nyanya:
Ranger
02-17-06, 07:03 PM
Oops! I corrected it. That did sound pretty lame, didn't it.
