: What replacement headlight for HID?
liv2wrshp
02-13-06, 10:53 PM
I have a 2000 Sport and the only place I found that has a replacement bulb for my headlights want's $140. Is that normal?
bengsxr
02-14-06, 06:09 AM
umm no take out the old ones and go up to napa about $10 bucks a bulb
liv2wrshp
02-14-06, 05:26 PM
Good call. So, they arent 139 right?
CateraSport2000
02-15-06, 05:18 PM
Umm... Xenon (HID) headlight bulbs on the 00-01 Cat Sport are completely different than the standard Catera bulbs. They are very expensive to replace so get ready to fork over some money and I wouldn't attempt to change it yourself as their is more risk for shocking yourself if you don't know what you are doing. This is the first time I've heard about a Xenon bulb failure, they should last a very long time but not forever :(
Jeff
liv2wrshp
02-16-06, 12:32 AM
Is there any way to tell if it's not the bulb? Maybe a controller module?
CateraSport2000
02-16-06, 12:54 AM
Yes, it could be a ballast. I don't know much about this stuff though. I'll see if anything is in the service manual.
Jeff
liv2wrshp
02-16-06, 08:31 PM
Man, any help you can give would be great. I hate that it only has one working headlight.
liv2wrshp
02-17-06, 08:18 PM
OK, quick update. I've noticed that when I first turn the headlights on, it flickers on for a split second but then shuts off. Any ideas? If it were totally out then it wouldn't even do that, right?
R-Caddy
02-17-06, 08:19 PM
how 'bout fuses and relays?
liv2wrshp
02-18-06, 04:10 PM
Where would I check that? Would they have a different one for each side since my drivers side works?
Thanks for all your help!
liv2wrshp
02-22-06, 05:59 PM
Anyone have any ideas? That sucks that I'm the only one who's HID has gone out.
CateraSport2000
02-23-06, 12:12 AM
You either have a bad bulb or a bad ballast...there's no real way to tell until someone checks it out. Keep us updated.
Jeff
liv2wrshp
02-23-06, 09:48 PM
If it was a bad bulb, would it go on for a split second and then go off?
CateraSport2000
02-23-06, 10:03 PM
Probably not... probably a bad ballast :( I have no idea what that'll cost! Good luck and keep us updated.
liv2wrshp
02-27-06, 09:34 PM
Does anyone know how I can test to see if it's a ballast? Would it be covered under the extended warrenty you think?
CateraSport2000
03-01-06, 11:31 PM
I was talking to a Jaguar tech about the Xenon issue and he thinks it may be a bad ground rather than a bad ballast or bulb because theoretically, the bulb either works or it doesn't and the same goes for the ballast. It shouldn't flicker at all if either is bad. To quote: "If you have a bad/loose corroded supply ground, or power for that matter, that could cause a flicker, and eventually go out when a full amp draw goes."
He says he fixes Jag HIDS all the time...
Jeff
liv2wrshp
03-02-06, 01:14 AM
Man, that's a great idea. I just checked it out and I cannot find where the ground wire for that light would be. Any ideas as to where to start?
Thanks for all the help!
CateraSport2000
03-02-06, 10:18 AM
I don't know a thing about ground wires on the Cat. Maybe the service manual could help you? If you don't have one already, you should pick one up!
liv2wrshp
03-02-06, 08:51 PM
Where can I get one? Sorry, I've only had hondas and never needed one. :)
CateraSport2000
03-02-06, 09:38 PM
Ebay is the best place... either 2000 or 20001 are essentially the same.
liv2wrshp
03-11-06, 11:34 PM
Does anyone have one they'd like to sell? Or maybe look in and give me a few pointers on where my grounds would be for my right hid light?
liv2wrshp
05-06-06, 11:18 PM
OK, I just took it to a shop and the bulb is defintely bad. They even switched it right and left and the bulb worked on the opposite side so it's definitley the bulb. Does anyone know where I can get a replacement or even what the part number is?
