SL1CK
02-05-06, 04:24 PM
Hey guys, I would like to post more, but everytime I try to I can't type in the text bog, its disabled somehow, sometimes it works sometimes it doesn't...sorta reminds me of a Caddy, but anyway, guess I got lucky
today...
Just have a few questions I'd like some input on:
1. When I drive the Caddy, and make a turn (a LEFT turn to be exact) I hear a loud popping noise coming from what sounds like the right tire. Is this a CV joint or what? If so, is it costly so replace/fix?
2. When I turn the AC on, the COLD air comes only out of the two right vents, and not the two LEFT vents. The two left vents blow warm/hot air, even when the AC is at COLD MAX. I talked to a mechanic yesterday he said that this is common for Cadillacs because of the electric motors that blow air that tend to go out and not work. True?
3. I know that Cadillac produced some Z rated Caddies with no limiter. My 96STS is one of them. Did they produce and 98-03 STS that were Z rated?
Also, pulled up my codes today...just want some input...
PC0101 - Mass Air Flow (MAF) Sensor Performance
PC0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
PC0603 - Control Module Long Term Memory Reset < ??
PC0717 < yes, yes, I know...
PC1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
PC1108 - BARO to MAP Sensor Comparison Too High
PC1406 - EGR Valve Pintle Position Circuit
PC1599 - Engine Stall or Near Stall Detected
AC1340 - Air Mix Door One Movement Fault
AC1348 - Very Low A/C Refrigerant Pressure (I just put some in after it had been low for a good while (but I never turned the AC on so I wouldn't mess it up))
RF2560 - RKE Message Validation Error
No SDM
No PCM
No IRC
No CCP
No RSD
Any advice is greatly appreciated. Thanks.
today...
No SDM
No PCM
No IRC
No CCP
No RSD
