This is probably a dumb question. I can't figure out how to disconnect the negative terminal on my battery. After I flip the latch it won't come off. What am I missing? I am trying to disconnect it in hopes my 6-disk changer will unjam itself.
once you flip that latch nothing else should be holding it in. try to wiggle it using a decent amount of force.
By the way, if you're trying to get the 6 disc un-stuck, what you WANT to do is disconnect both the pos and neg, touch them to each other, then reconnect them and see if it worked. If not, try a couple more times. If still no good, you're probably screwed like I was with the 07 STS I sold. Good luck.
You might try pressing and holding the eject button. That's supposed to eject all discs. Might not help with a physically stuck mechanism, but can't hurt.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
