: NAV replaced,Comp Mode not working cant find TSB
Got5onit
01-31-06, 05:21 PM
My nav unit was replaced due to a peeling knob and now the car will not go into competition driving mode. The TSB is not in the CTSV Faq anymore. Anyone have a newer TSB number?
ctsvett
01-31-06, 05:41 PM
http://www.cadillacfaq.com/faq/tsb/data/PIC3174.pdf
Until I can impliment a search (which will be a while since they are all PDFs), simply "view all bulletins" and do a text search (edit--> find on this page)...
If anyone has any experience with PHP searching thru PDFs, let me know
Reed
01-31-06, 06:23 PM
That TSB doesn't really address the problem you have. It addresses the calibration number of the Tech II.
You need to go back to your dealer and tell them that they need to perform the radio setup through the Tech II. It's in special functions IIRC.
ctsvett
01-31-06, 06:59 PM
ops... bad link... here ya go...
http://www.cadillacfaq.com/faq/tsb/data/pic3174.pdf
Reed
ctsvett
01-31-06, 06:59 PM
Reed
Ryan's '05-V
01-31-06, 09:19 PM
I had the same program and basically the dealer needs to program the Nav unit for a V and not CTS. It's very annoying to have to return to the dealer for a problem that should have been avoided on the dealers end but it happens and is not a big deal. In my case I have had to return several times because my dealer just hasn't paid attention to details like this.
It should be simple. I used my Comp Mode daily so it sucked not having it.
LV_V
01-31-06, 09:27 PM
Make sure you let them know what the Tech 2 update is. My dealer had no idea and had to get on the phone with a GM engineer to get the process rolling. Don't let them tell you differently; you need the Tech 2 ;)
Got5onit
02-01-06, 05:16 PM
Took it in and my dealer had my out in about half an hour. Comp mode is working now.:bouncy: :bouncy:
cts-v ls6
02-01-06, 08:49 PM
Got5onit,
I put in a '06 rear and my comp mode and abs trouble lights came on. Was your abs light on as well? I'm wondering if I should take it to the dealer. Do they have to reflash the ECM? I have a tune i'd hate to lose.
Jack
ewill3rd
02-02-06, 07:01 AM
As far as the radio goes, a lot of techs don't realize that most of the newer radios require a "setup" procedure.
I must confess I got burned a few times.
Now I always check the manual and do any special setup procedures that are required.
Most of them used to be plug and play, not so anymore.
Glad they got it fixed.
