: brake noise (not braking)
twentyon20s
01-30-06, 05:49 PM
I've noticed a squeaking coming from my breaks on occassion coming from my brakes when im NOT braking. I assume it's the brakes because as soon as i press down on them the sound will stop and/or blend into the normal brake squeal. I've had the dealership check it out before and they told me everything was ok... anyone else have this problem?
Also, i was hoping to get my differential changed today before i put my exhaust system on this weekend, but the (other) dealership told me they cant assess the sound until i change my front tires (go figure), but has anyone had or know of any warranty issues that could result from B&B headers and exhaust (basically, will i still be covered if the rear diff. goes?)
50 4Ever
01-30-06, 06:05 PM
From what you are describing on the brake noise it sounds to me like the GM wear indicator. When the pads are worn a "chirping" noise can be heard and goes away when you apply the brakes. But, since the dealer checked it out that must not be it.
:banghead:
heavymetals
01-30-06, 06:20 PM
I wouldn't recommend you mod anything till you get your problems fixed first.
