: RE050 265/40/18s going on today...
AustinV
01-25-06, 01:23 PM
The tires arrived today. I'm having them installed at 2:30. Assuming there is no significant rubbing on the front, I will keep them on. I'll take some pictures and post later for those that are interested.
brtnharv
01-25-06, 02:16 PM
I'm assuming these are going on stock wheels, love to see how the look.
mlg
01-25-06, 03:12 PM
let us know how ride/drive changes.
AustinV
01-25-06, 03:35 PM
Yes - going on stock wheels all the way around. I think it will look pretty mean. I'll post some pictures and when I have performance info I'll put that up as well.
obzidian
01-25-06, 05:18 PM
update?
Flexinator
01-25-06, 06:23 PM
They a little wide for stock wheels? (sidewall bulge) ?
AustinV
01-25-06, 07:54 PM
UPDATE:
I am totally surprised here. On another thread I had about this, someone posted that the RE050 Extended Mobility tire looked narrow based on the specs. Sure enough - the 265/40/18 looks to be only a hair wider than the the stock 245/45/18 (it is probably 1/2 inch wider overall). There is no rubbing with the car sitting still and turning the wheels lock to lock.
Something interesting I learned about this particular model of RE050. The local Bridgestone tire shop did not know this. I had to call Mercedes, spoke with Tire Rack several times, and had a buddy at Discount Tire hook me up. The version of the RE050 I went with is listed below:
(http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE050&partnum=64YR8RE050MOE&vehicleSearch=false&fromCompare1=yes&place=0)
Technically this tire is not a "runflat". I was told that it did not get the "runflat" designation because it did not meet the minimum requirements for a "runflat". HOWEVER, it is designed to be driven 15-20 miles on zero pressure at 50 mph. Apparently, Mercedes wanted a tire that provided some extended mobility in the event of a flat, but did not want to impede on comfort with a super stiff runflat sidewall.
The ride was noticeably quieter on the way back to the office. I'll update on performance once the tires have been broken in. For those of you wanting to stick with a runflat(like) tire I think this may be an excellent alternative and it's a bit cheaper than the stock setup.
I do have pictures and will post them later.
Dreamin
01-25-06, 08:01 PM
Great info :thumbsup:
urbanski
01-25-06, 08:45 PM
yep, so great I'll add it to hot topics.
AustinV
01-26-06, 12:25 PM
Here are a few shots of the new tires on the car. I'm loving them so far!
Staxxin
01-26-06, 12:33 PM
Great info... You're right, they don't look any wider!
Flexinator
01-26-06, 12:51 PM
Look better than I thought, not too wide, not too thin!
Vdrenaline
01-26-06, 03:08 PM
Best thing about going with a slightly wider tire is it will protect the wheels from curb rash.
Dreamin
01-26-06, 04:44 PM
Have you had a chance to drive them really hard yet? Any rubbing in front?
AustinV
01-26-06, 04:58 PM
Um...Yes...I couldn't help myself today driving down a twisty road and I had to take a few 90 degree turns extra hard just for the fun of it. I am impressed with the grip these tires have cornering and in high speed lane changing. I took them up to 120 today and they felt very smooth and solid. They are running at about 38 psi hot - this may be a little high, but the ride is not too rough.
I have not seen or felt any signs of rubbing. I will tell you that we tested the fronts yesterday on the ground (without the car moving). With the wheels turned all the way to the left or right we noticed one area that might rub. The tires were very close to the brake cooling vents when turned inside without any extra load on the suspension. The tech and I agreed that under severe cornering the tire "might" rub in this area, but I doubt it.
thebigjimsho
01-27-06, 12:38 AM
You didn't get the As though, huh?
AustinV
01-27-06, 11:28 AM
Did not get the As - the A version does not come in 265/40/18. I'll take a close up of the sidewall on the tire. I believe it actually says "MOExtended" after the size.
