View Full Version : 2003 deville problem
roquesr
01-24-06, 08:42 PM
hey guys i need some help .i just noticed a light tapping /rattle coming from the engine. the car has 54000 mi, it is noticeable at idle up to1500 rpm then you cant tell .its not a constant noise but it happens every couple of seconds,also every once in a while when i go to start the car cold it will stall but it will start right up.the rpm will be @ 450 then move up to 1000 then back down to 650after a minute .the tapping is more noticeable when the car is hot not cold.any advice would be apreciated thanx.:hmm:
JimD
01-24-06, 09:13 PM
Any trouble codes (DTCs)?
turbojimmy
01-24-06, 09:37 PM
A 2003 stalling under any conditions is not good. Is it under warranty?
Tombo47
01-25-06, 02:38 PM
turn the key into a slot before ignition and depress the on/off and info iup button and wait to see if codes pop up. there will definately be one ebcause of the stall, just to inform you that the car has stalled. There should be at elast 1 additional to that stating the area of problem. Write the code down and google it, youll find out what it means.
roquesr
01-27-06, 03:18 PM
the vehicle is out of waranty.ill check to see if there is any code ,il get back to you on that. wasnt there a cam sensor or crank sensor issue on the 4.6 could nt that throw my timing a little off and that could be the noise?
Ranger
01-27-06, 06:29 PM
It has both crank and cam shaft sensors but I don't think either will cause a tapping or rattling sound. Check the belt tensioners, idlers and accessory bearings as well as the belts.
Gilbo
01-27-06, 06:39 PM
Hi Roquesr,
I'm Gilbo and just signed up... I havebn;t figured out how to use this Forum yet. I wrote the note about my 89 Deville that stalls, skips, coiughs whenever I use any battery power, but dion;t knowhow to tell you how to find it...Duuuuh?
I had a tapping too but it would cycle. I finally figurred out it was the AC compressor. Problaby not your problem but I'd never heard an AC compressor make a sound like that.
Gilbo ..... Oops, I clicked on "Quick Reply" and now see I should have used Post Reply
roquesr
01-30-06, 08:31 PM
thanx for the info guys ,il check some of the pulley etc this weekend. any one know where to get a real repair manual for the caddy?
Ranger
01-30-06, 08:49 PM
Ebay or http://www.helminc.com
