View Full Version : How do I remove the Dash?
Seekerhiker
01-24-06, 03:17 PM
I need to chack/change a light in my Instrument Panel, how do I get at it? 1 998 Deville Concours, Analog Cluster.:hmm:
cadi197
01-25-06, 12:09 PM
It should be pretty easy. There are 3 or 4 bolts under the defrost vent, and then you will have to remove all your air vents and you will find bolts behind each of those vents. After you get those removed, should just lift up. Besure you disconnect your senors by the windshield before pulling the dash cover out of the car. Good Luck.
