View Full Version : another noob asking a speaker ?
NINESIXFLEET
01-20-06, 04:48 PM
ok a 96 fleetwood non tuner in the back.....are the door speakers 6 1/2?
also i put a after market deck in (jvc) but now its sounds kinda crappy..
my question is do i have to bypass any kind of amp or anything?
thnx in advance
Big_Blue
01-20-06, 11:38 PM
Your door speakers should be 6 1/2 and if your speakers sound crappy you could have the wires crossed. If you have a amplified system it shouldnt play at all unless the factory amp is turned on with a wire. You should have noticed when you had installed the wire harness.
Speaker size chk here
http://www.crutchfield.com/
To identify your wire harness if amplified or not
http://www.installdr.com/Harnesses/GM-Wiring.pdf
