: Trying 265/40/18 All Around - What to look for?
AustinV
01-18-06, 03:09 PM
I've got a local shop that is going to put a set of Bridgestone RE050 265/40/18s on the V. They will try the front first and if the rubbing is too significant, then we'll go to a smaller size. As far as rubbing goes, where is this most likely to occur?
I also noticed (according to Bridestone's site) the overall diameter of the RE050 is 26.6" - the same as the stock tire. Now, Tire Rack has it listed at 26.5", so I don't know which is right.
Anyway - thoughts are appreciated.
Mat347
01-18-06, 03:11 PM
When you turn, you'll see the tight spots.
AustinV
01-18-06, 03:16 PM
Is the rubbing on the suspension components or on the fender or both? I'm an idiot here, so help me out if you can. I'll get to see for myself, but I got the impression from other threads that not everyone has had the same rubbing issues with tire upgrades.
Dreamin
01-18-06, 04:21 PM
This guy is running 265's in front: http://www.cadillacforums.com/forums/showpost.php?p=499634&postcount=27
And there are 3 RE050 tires in a 265/40/18... the regular non-runflat, a Porchse OEM non-runflat, and the runflat. The runflat Dia is 26.5". And the runflat looks like a pretty narrow tire... you might be ok.
Mat347
01-18-06, 04:36 PM
Inner and outer fenders.
AustinV
01-18-06, 06:11 PM
Excellent - thanks for the responses. I'll keep you all posted and put some pictures up once I have them.
1BDCADY
01-18-06, 08:09 PM
A buddy of mine is running those in the PS2s and hasn't complained of any rubbing at all. I haven't driven the car since the tires but I would be curious if it handles any different, he said it fine. Those tires do bulge a little on the stock wheel but not too bad.
Paul
