View Full Version : The new diff
Joey'sVee
01-17-06, 10:14 PM
Will the new diff be cast iron? Also will it be live axal? Seems like we would need the answer to both questions to be yes. :cool2:
I would think it would be both, but I'm a dumbass :cool: so if the answer to either of the above questions is no can you explain why. :hmm:
Thanks for the help!!! :highfive:
Florian
01-17-06, 10:56 PM
housing is aluminum, live axle? like indep.rear? yes, according to MM it will be the same as our current V. Iron, no need, that friggin housing should take a landmine its so thick.
F
heavymetals
01-17-06, 10:58 PM
Live rear axels do not lend themselves well to independant rear suspensions.
As for cast iron............
Joey'sVee
01-17-06, 11:09 PM
The live axal would eliminate wheel hop and the cast iron would take more of a beating...our current rear is aluminum.
heavymetals
01-17-06, 11:19 PM
It would also turn a real nice road car into a stoplight to stoplight car.
Whatever floats your boat.
And don't count on someone investing in a cast iron mold for the limited # of rear ends for the V one is gonna sell.
Parker
01-18-06, 01:16 AM
The center is billet aluminum, with bad ass half shafts, and he has a revision to eliminate the wheel hop all together.
ewill3rd
01-18-06, 07:05 AM
The Corvette rear is made of aluminum. The real problem is inside the case, not so much the case itself.
I wouldn't be so sure that Cast iron would hold up better either.
I am no scientist but it seems with the alloys we have these days that they can make some pretty strong really light stuff.
I haven't taken one of these units apart yet so I can't really tell you where the problem lies.
If I had to guess I'd say this is maybe more of a leakage problem than anything. I might try to start a little private study of my own if I can remember.
Joey'sVee
01-18-06, 08:39 AM
Thanks guys. I was just curious on this.
What wil need to be modified to get this to fit. The exhuast, I assume and what else?
madman69
01-18-06, 12:47 PM
The exhaust is the only thing that will be modified. Everything else is a bolt in. You can remove all my parts and put the stock junk back in.
Joey'sVee
01-18-06, 04:25 PM
Sounds awesome!!!
BadCad
01-18-06, 04:48 PM
mm69:
How so? Those of us with B&B or Corsa, etc.; we need modification of these to make this diff fit?
Joey'sVee
01-19-06, 08:52 AM
Yes!
