whiteseville
01-17-06, 10:19 PM
I have a 1993 seville and dont have traction control.I cant get to the abs codes in my diognostics mode and want to see what is makeing the light come on.:helpless:
Can someone please help me.:cool2:
CadillacSTS2003
01-17-06, 10:21 PM
you have to have TC ive never herd of them lacking one and juz b/c you dont have a button to turn it off doesnt mean you do not have it my dads 93 etc had tc but no button to disengage it
whiteseville
01-17-06, 10:24 PM
Well then I dont have tc.I only have four modes to check for codes and not one starts with T for tc or abs. So since I dont have this there has to be another way right.
CadillacSTS2003
01-17-06, 10:34 PM
i wish i could help you however your car uses obd1 im more familar with obd2 im sorry i cant be of more help
whiteseville
01-17-06, 10:40 PM
Well thank you anyways.A reply is good enough for me.
CadillacSTS2003
01-17-06, 10:49 PM
perhaps this web sight may be able to help you this is what i use to figure out what my codes mean they also have info on the obd1 system
http://myweb.accessus.net/~090/cadidiag.html
whiteseville
01-17-06, 10:51 PM
Lol I have that entire obd 1 diognostics code pages printed and by what they say, I cant /dont have it to get to the abs mode.
I am not sure what you are asking but, I am sure you have traction control. Get it on snow or ice and lay into the throttle. Traction will engage and would will be aware of it. You probably will get a TRACTION ENGAGED message.
whiteseville
01-18-06, 09:20 AM
Well I will try this but I dont have any type of diognostics mode with the T for tc or abs.
My car is weird.Can someone clear this up also I have a base modle 93 seville
and have the elctronic suspension up front and thought that was only with the N*.
Eldyfig
01-18-06, 12:16 PM
You have a Seville with a 4.9?
In your first post, you mention a light has come on. What light are you referring to?
Ultimately, you want to find out why the light is coming on, correct? Any other codes in the other sections?
whiteseville
01-18-06, 11:48 PM
Only the ones stated above
My ac is low also but dont know if that will throw a code.
Eldyfig
01-19-06, 07:53 AM
Low refrigerant will set a code if it is low enough. If the code sets, the compressor will be shut down.
What light is coming on? ( you mentioned a light in your first post)
ewill3rd
01-19-06, 07:59 AM
What modules are listed in diagnostic mode, by that I mean what abbreviations do you see?
What codes come up when you do the self test?
Krashed989
01-19-06, 07:02 PM
Well, I know that the diagnostics mode is not completely comprehensive with what codes it gives out. Some of the codes you need the scanner tool to read, maybe this is one of them.
