JSMeloche
07-27-04, 09:42 AM
Good morning everyone. I changed the A/C compressor on my 95 STS this weekend and tough my experience could help others. So here is a step by step to A/C removal. Not a very hard job but the space is kind of tight!
#1 Have the A/C system evacuated by a shop or a dealer
#2 disconnect the negative post of the battery (safety first children!!!)
#3 Jack the car, I used a ramp on the driver side then floor jack and stand on the passenger side
#4 Remove passenger side front wheel
#5 Remove the front plastic shield in the wheel well (3 Phillips screm) and the plastic cover behind it (10mm and 8 mm screw)
#6 Undo the accesorie belt by inserting a 1/2 breaker bar into the tensioner and pulling toward the front of the car
#7 Remove the front shield underneath the car, this is the plastic shield in front of a large beam that run accross the car
#8 Now the dirty part! Go underneath the car and remove the oil filter
#9 Remove the rear bolt of the compressor. This bolt is located right next to the oil filter. You acess is with a deep socket and an extension inserting the socket trough the front (shield removed) between the A/C line.
#10 Remove the 3 front compressor bolts trough the wheel well.
#11 Undo the bolt holding the A/C lines. To do this you will probably need some help. Ask your friend to pull the compressor in the wheel well while you are underneath the car to get extra room, I did it with a pry bar and a floor jack to hold it in place. The bolt is between the 2 lines (14 or 15 mm) I recommend the use of a low angle wrench!!! the angle is so limited that I could only get 1 or 2 click out of my regular ratchet
#12 Pull the compressor trough the wheel well, undo the electrical connection !!!Success!!! the compressor is out
#13 Manual recommend that you put the same amount of A/C lubricant in the new compressor has there was in the old one. Mine was bone dry so i putted 4 oz (dont quote me on this, manufacturer recommends 5 oz, GM tech recommends only 2 oz) Put the plug that came with the new compressor so the oil wont spill everywhere
#14 Remove the bracket on the rear of the old compressor (2 bolts) and reinstall it on the new one
#15 Insert the new compressor trough the wheel well
#16 When i did mine i did NOT plugged back the electrical connection or the hose that connect to the compressor. I did not want to contaminate the new compressor with metal shaving from the old one. I can't see any other way to replug the lines then to remove the compressor but the dealer tech managed to do it, dont ask me how!!!
#17 Insert the 3 front bolt loosely
#18 Insert the rear bolt tightly
#19 Tighten the 3 front bolts
#20 Reinstall the oil filter, this might be a good time for an oil change since you are already underneath the car!
#21 Reinstall the belt, this is a good time to install a new one because you have easy access to the lower pully trough the wheel well.
#22 You will also need to change the dryer (most A/C compressor warranty ask you to do this to have a valid warranty!!!) The dryer is the metal can sitting "in" the coolant tank. Just one bolt to remove and 2 A/C lines. DO NOT unseal the dryer before rechargin the system!!! you will ruin the moisture absorbing property of the dryer if you do.
#23 Reinstall the plastic shield, wheel, reconnect battery
After this I brought my car to the dealer and had them flush and recharge the system, and replace the orifice tube.
TOTAL COST: (in Canadian dollar including taxes)
Dealer flush 130$ including diagnostic of the blown compressor
A/C Compressor 119$US + 30$US s/h + 67$ tax and UPS charges = 270$ CAN from EBAY
Acc. Belt 31.50$ @ Canadian tire
Dryer 121$ @ GM dealer
8 oz oil PAG-150 23$ @ Local jobber (dont got to AutoPart Extra, they charge 36$!!!)
Dealer recharge 236$ Including Replace orifice tube labor 49$ Orifice tube 4.85$ Oil, dye, refrigerant and labor 150$
TOTAL: 815$
ESTIMATED DEALER REPLACEMENT COST (excluding taxes) from Boulevard Chevrolet Oldsmobile Cadillac Ltée in Hull, Québec
A/C Compressor 1000$ new OR 600$ rebuilt @ Dealer OR 392$ rebuilt @ Canadian Tire
Acc. Belt 45$
Compressor labor 315$ 3.5 hours @ 90$
Flush labor 180$ 2.0 hours @ 90$
Recharge and etc 150$
TOTAL: Between 1300 and 1800 with taxes depending on the compressor
I hope this will be usefull!!! and dont hesitate to correct me if I was wrong on some point
TOTAL: 815$
Acc. Belt 45$
