agood1
01-15-06, 02:30 PM
I am working on replacing the Steering rack in my 98 SLS. Alldata says you must 1st lock the steering column before you remove the rack. It mentions a special tool that is inserted in the lower part of the steering column just in front of the steering wheel. Do I really need this special tool or can I just use a screwdriver or somthing?
Here's that Alldata says:
Steering Gear Removal and Installation
REMOVAL PROCEDURE
Tools Required
J 42640 Steering Column (http://www.alldatadiy.com/alldata/AFI~V6017414~C32320~R0~OD~N/0/56775861/62803304/62803317/62803318/34853741/34864218/34864219/34864220) Anti Rotation PinNotice: The wheels (http://www.alldatadiy.com/alldata/AFI~V6017414~C32320~R0~OD~N/0/56775861/62803304/62803317/62803318/34853741/34864218/34865428/34865429) of the vehicle must be straight ahead and the steering column (http://www.alldatadiy.com/alldata/AFI~V6017414~C32320~R0~OD~N/0/56775861/62803304/62803317/62803318/34853741/34864218/34864219/34864220) in the LOCK position before disconnecting the steering column or intermediate shaft (http://www.alldatadiy.com/alldata/AFI~V6017414~C32320~R0~OD~N/0/56775861/62803304/62803317/62803318/34853741/34864218/34864219/34864450) from the steering gear. Failure to do so will cause the coil assembly in the steering column to become uncentered which will cause damage to the coil assembly.
REMOVAL PROCEDURE
Tools Required
