: Water under carpet 1969 caddy
01-13-06, 05:03 PM
Hvae a 1969 sedan deville getting allot of water under the carpet.... any fix
01-14-06, 03:01 PM
any help
01-14-06, 03:48 PM
Which area, Driver's side footwell? Trunk mat? (Like mine currently...)
My suggestion would be to crawl unto the affected area and look up with a flashlight while someone sprays the car with a hose. Common problem areas are rust around windows, allowing water to seep in around the seals. Sometimes the only way to spot the rust is removing the trim. My '68 has two small spots partially hidden by the trim at the bottom corners of the back window. After a good rain, my trunk looks like a pool.
