: Crankshaft posistion sensor: 97' cater, where is it located
gixxer_751
01-09-06, 10:47 AM
I've lurked on this message board for a while to get tips on getting my troublsome catera up and running. Well beside the $600 valve cover job:crybaby: I had done @ 100,000, my crankshaft sensor is out. I've got the new one in hand ($70) but needed to know where it was located, so that i may change it myself. Any info would be appreciated.
meyema03
01-09-06, 03:19 PM
http://www.alldatadiy.com/alldata/AFI~V5986460~C32314~R0~OB0~P2R0H~N/0/56775861/62803304/62803305/62803306/34853741/34857029/34857030/56562517/14461280/78489552/62388834
REMOVAL
Numbers in text in parenthesis correspond to numbered components in image.
Disconnect the wiring harness from the Camshaft Position (CMP) sensor (1).
Remove the A/C Low Pressure line bracket.
Remove the fastening bolt for the CMP sensor.
Remove the CMP sensor and the O-ring seal from the camshaft cover.INSTALLATION
Thoroughly clean the mating surfaces of the CMP sensor (1) and the camshaft cover.
Install the CMP sensor with a new O-ring seal into the camshaft cover.
Install the fastening bolt for the CMP sensor.
Install the A/C Low Pressure line bracket.
Connect the wiring harness to the CMP sensor. Ensure the correct cable routing.that should get you there
gixxer_751
01-09-06, 03:51 PM
yeahhhh!!! meyema03 i've searched throughout the entire catera section of the forum and found discriptions but nothing as good as this, thanks
**armando ***
meyema03
01-09-06, 04:51 PM
no prob hope it goes well
AllenPacla
01-09-06, 09:45 PM
I don't know if you notice but the image says Hyundai. If I am not mistaken, the crankshaft position sensor on a 97 Catera is right beside the oil filter under the engine. You will notice it because it has wires connected to it wrapped with some heat protection material.
meyema03
01-10-06, 06:48 AM
yes you are right that is where it is located but the picture i posted has changed since yesterday seriously the one i posted was of the location of the crankshaft posistion sensor damn computers
meyema03
01-10-06, 03:50 PM
!!!!REVISED THIS IS THE CORRECT PICTURE AND IT WILL NOT CHANGE!!!!!
(now that i know how to post a picture)
http://home.fuse.net/cateraheadquarters/camshaft%20position%20sensor
REMOVAL
AllenPacla
01-10-06, 09:42 PM
Wasn't the title of the post Crankshaft position sensor? The one posted with the image is about Camshaft position sensor.
gixxer_751
01-11-06, 09:23 AM
yes,, correction it is the crankshaft sensor.. i found where the sensor inserts in the block but cant figure out where the clip side of the sensor goes. any help would be appreciated.
Tronicv6
01-11-06, 02:12 PM
ffs get it right look here
http://www.cavweb-forums.co.uk/showthread.php?t=62628
gixxer_751
01-11-06, 02:31 PM
Bingo!
AllenPacla
01-11-06, 10:48 PM
I guess I was right as well in saying that it's beside the oil filter.
gixxer_751
01-11-06, 11:04 PM
A sticky possibly? Excellent link!
