wecampbe
01-03-06, 08:58 PM
When replacing the crank position sensor in a 2000 Deville what is the procedure to "Learn" the new sensor.
| View Full Version : Crank Position Sensor wecampbe 01-03-06, 08:58 PM When replacing the crank position sensor in a 2000 Deville what is the procedure to "Learn" the new sensor. Ranger 01-03-06, 10:09 PM I am not sure there is one. Just replace both of them and you should be good to go. hogstamogsta 01-03-06, 10:56 PM where r they located on a 96? Ranger 01-03-06, 11:27 PM Not positive but I beleive they are on the front (passenger) side of the engine. turbojimmy 01-04-06, 07:20 AM When replacing the crank position sensor in a 2000 Deville what is the procedure to "Learn" the new sensor. You need the Tech2 to do it. Just replace them. If you don't get a P0300 code (misfire) then you're good. Most people don't need to run it. If the PCM detects a misfire after you replace them then you'll need to have the stealer run the CKP relearn procedure. Jim | |
