View Full Version : How do I spot a head gasket starting to go?
N0DIH
01-03-06, 02:58 PM
Being I rarely get to see my mom's N*, and I will next week, what is a way to keep an eye out for her to ensure she doesn't have a head gasket going?
And, what is preventative maintenance on it to ensure it WON'T ever blow?
The car is a 97 Deville 275hp.
Thanks!!
zonie77
01-03-06, 04:05 PM
I thought this was beaten to death...
Coolant loss with no visible leak, overheating going up hill or heavy accelleration,
missing when cold.
There is no way to prevent it from EVER happening. To put it off as long as possible do a coolant change regularly.:stirpot:
A 97 should have had a coolant change in 2002. 5yrs.
Katshot
01-03-06, 04:24 PM
And don't forget the coolant tabs!
auroradude
01-07-06, 03:31 AM
What exacdtly are the coolant tabs? I could never find them, and Im pretty sure the service dept didnt ever put them in my engine when they changed the coolant. I bet you they didnt. What exactly happens if you forget the tabs?
zonie77
01-07-06, 11:31 AM
The tabs are a sealant (ginger root is one ingredient) that plugs nuisance leaks. It doesn't do anything for major leaks.
auroradude
01-07-06, 11:55 AM
are you supposed to put them in each time the coolant is changed? if u dont can the head gasket be put at risk?
mcowden
01-07-06, 02:02 PM
The coolant supplement required on Northstars is one of three products:
* Six of the GM Cooling System Supplement pellets (available at any GM dealership)
* Six of the Bar's Leaks HD Tablet Stop Leak tablets (Bar's part number HDC)
* Two tubes of Bar's Leaks Golden Seal Powder (Bar's part number G12BP)
One of these products should be installed to the radiator hose before refilling the system. They should never be installed in the surge tank. This should be done at every coolant drain and refill. For traditional antifreeze cars, 1995s and older, that means every 2 years or 30,000 miles. For cars with Dexcool coolant, 1996 and newer cars, that means every 5 years or 100,000 miles. It's very important to eliminate air from the cooling system, so I think it's also wise to check the vapor purge line every coolant change to ensure it flows freely.
zonie77
01-07-06, 03:48 PM
Doesn't have anything to do with head gasket leaks. It's only for minor, low pressure leaks.
N0DIH
01-11-06, 02:16 AM
Well we did the plugs yesterday and 1 plug (#6) had some sparkly stuff on it that I have always identified as antifreeze.
Has anyone ever looked closely at the plugs when they changed them?
The car is running factory installed antifreeze, as per the 1997 FSM, no changes to antifreeze for 100K. It lists no changes for coolant until >150K.
The only thing we really don't have time for is throttle body cleaning. I would like to, but I don't have time.
zonie77
01-11-06, 11:11 AM
Even if the FSM gave 150k the jugs and all the other literature I've seen say 5ys OR 1xx,xxx miles. That means it should have been changed.
Ranger
01-11-06, 11:22 AM
I agree with Zonie. A '97 should have been changed 3 yrs. ago.
N0DIH
01-16-06, 11:29 AM
So why would Cadillac steer every 97 Deville owner wrong? Would they really risk it?
I don't buy that personally.
Although I do agree it should be changed, with all the years and years of GM doing maint schedules, I find it hard to believe that GM would post a schedule that has info in it that would comprimise the life of the car.
Katshot, what did you do with the limo's? Or did they get a commercial maint schedule that isn't posted in the FSM?
DASTONE
02-03-06, 09:21 PM
The first thing I would do is stop towing that airstream behind it.
davesdeville
02-06-06, 04:06 AM
^^Why'd you dig up a 2 week old thread to say that? Plus, that's a pic of a Fleetwood Brougham (I'm assuming a V4P car) which is rated to tow 7000lbs.
cart69
02-06-06, 02:53 PM
good thing i saw thism y 96 sts has water in it now, bad head gasket, so i remember to run dexcool after i am finished with the motor, that thought hadnt crossed my mind yet!!!
mtflight
02-06-06, 05:55 PM
The tabs (or GoldenPowder) themselves do not prevent headgasket damage, but they MAY help prevent the leak that could lead to an episode or two of overheating, which COULD cook the headgasket.
mwwebmstr
02-09-06, 03:13 PM
I was under the impression that the additive tabs were used to mitigate the corrosive nature of coolant and prevent the steel inner part of the head gasket, as well as the entire coolant system from corroding, rusting, etc.
mtflight
02-09-06, 08:36 PM
Nope. The tabs are ground up walnut shells and ginger root. They expand to seal nuinsance leaks caused by casting porosities.
You were on the right track though: the coolant must be replaced every so often according to schedule, in order to prevent corosion. While it's cooling capacity does not degrade, the anticorrosive agents deplete.
davesdeville
02-10-06, 01:02 PM
They do - kind of. If the coolant starts to corrode the headgasket, the barsleak sealant will get into the corroded area and help prevent it from spreading and worsening.
Ranger
02-11-06, 09:53 AM
Head gaskets are under an intense amount of pressure. The tabs do nothing to prevent or cure a bad head gasket. NO addative can do that. Mtflight is correct.
cl1986
03-05-06, 11:41 PM
So what if i have missing coolant and no overheating even going up the mountains on steep grades??
I saw the check coolant level a couple weeks ago, put in about a gallon of mixture. I just went to centennial wy to snowmobile and when i got back the check coolant level was on again. 1500 mile trip plus about 2 weeks of driving. The hill from centennial is about striaght up, no overheating, no message. I got the message when i got home.
Could the water pump leak like they do on the chevy pickup and im not seeing the leak?? When i got to the lodge something was smoking very faint, could have been from the snow up there at the lodge. This happened all three times. No overheating though. Could it leak out the waterpump and burn off somewhere??
The car is always garaged and have never seen any puddles. Have had the car just over a year now.
Ranger
03-06-06, 12:22 AM
Yes, it could be leaking and burn off (evaporate). Have the cooling pressurized when cold and let it sit overnight. If there is a leak, it should show up.
JohnnyO
03-07-06, 11:48 AM
Also you can send your old oil to a lab, which besides telling you how your oil and engine are getting along, will find even miniscule amounts of coolant in your oil and you can "head off" a problem (pun intended) before it gets bad.
www.blackstone-labs.com
