View Full Version : '94-'96 FW rear speaker plug and play option?
HotRodSaint
01-03-06, 12:09 PM
I just came across a Mazdaspeed6 'subwoofer' that was removed from the car. It's an 8" 2-ohm speaker with built-in amp.
Bad news is they only get 1 speaker per car, so I need to find another.
But this could be a low cost stereo mod, since it would be a plug in solution.
Katshot
01-03-06, 12:36 PM
All I did with my Fleetwood was install a ported box w/10" sub on the one side of the trunk and it sounds great! Just patched it into the R/R speaker leads and used a filter to cut everything above 150 out. Used a 300w amp mounted on the box powered via power and ground run from the engine compartment. It was a simple install, and sounds great! Use the cavernous size of the trunk to your advantage!
N0DIH
01-03-06, 01:26 PM
Typically you only need 1 sub, the low freq output is almost always mono anyway (bass guitar, 1 mike/input, panned 50% each speaker, synthesizers panned 50% each speaker, but might be 2 channel, but often not used as such). And being low freqs go through about anything, you will likely not be able to tell that there is only 1.
I think the new body style 2000-up Suburbans/Tahoes come with them factory, and only have 1 also.
Katshot
01-03-06, 03:38 PM
Things I've learned about subwoofer installs:
1. More is not usually better unless you just like noise or are trying to impress the ignorant.
2. Bigger is only better to a point.
3. Don't go cheap/light on the amp.
4. Don't go cheap/light on the wiring.
5. A properly chosen and installed sub is usually plenty for any normal application (see # 1 above).
N0DIH
01-03-06, 05:43 PM
Aye!
We have a pair of subs at church, and they can rock the house in a 1200 seat auditorium. I think they are only 15-20in cones. 1000+ watts each. And they will MOVE you....
Katshot
01-03-06, 09:20 PM
Aye!
I was refering to subs in cars. A freind of mine is a DJ at a number of clubs in our area and he would certainly NOT be able to deal with only ONE subwoofer. His are bigger than a friggin' refrigerator freezer! Totally different acoustics in action there.
HotRodSaint
01-04-06, 12:07 AM
So you are suggesting I remove two speakers and replace them with one?
Maybe I could make the other hole a Champaign cooler?? :bigroll:
Brad VV
01-04-06, 05:41 PM
Has anyone cut holes in the rear deck in-between where the 6X9's are so that more air can be moved??
I also only have one 10" sub, but there is a ton more bass when I pop the trunk and it only opens a few inches. I was planning on cutting the holes in the deck, but was wondering if anyone else had done it with any luck.
I hope this isn't wrongfully cutting in on someone else's thread....if so, I apologize.
Brad
