View Full Version : Catera problems fixed!!
Mike Lee
01-01-06, 11:05 PM
1998 Catera 64000 miles, This car has occupied a lot of my time trying to
figure out what problems that I have had. I purchased the repair manuals
on ebay for $35 and a engine scanner from Sears for $135. I also have been
searching user groups like this and coming up with a lot of information.
The car is immaculate and I feel that everything is running perfectly
at this time. Even with all of the problems I am in love with this car
It is quick, solid and handles well.
I have done all possible maintenance on this car including replacing
all of the brake pads before needed. I recommend this car to anyone
that is willing to make a maintenance and repair commitment to get their
car up to snuff when they purchase the car.
1 Took the car to the dealer and had them check to make sure that the
Recall work had been preformed for the timing belt and pulley, it was.
2 Problem with idle, removed and cleaned the idle valve - same problem.
3 Lost spark in #3 and #6 cylinder, replaced ignition coil pack myself
3 hrs. not a bad job. Paid through the nose for the part - $280.00
4 Radio not turning on while the engine is running, blown fuse due to
Poor connections at the secondary water pump. Fixed connections and replaced
Fuse all ok.
5 Engine running rough at idle and while driving, took it to the dealer they wanted $1100 for new plugs and wires. The wires were beautiful and I could not believe that they were bad, I was sure that there was an injector problem that is why I took the car to the dealer. Replaced the plugs and wires (2hrs.) with a cost of $226.00 and it runs as if it was new, steady idle and a ton of power.
NJ_Catera
01-04-06, 08:48 PM
I can't believe the $1100 for plugs and wires. That's Y I avoid Caddy. I had the same problem with mine last spring...Wires looked almost new, but they were bad. Spent about $236 for wires at a very reputable dealer here Upstate NY.
