: Help No Heat
01-01-06, 07:02 PM
Hello I'm New To Site. I Have A Couple Of Problems. There Is No Heat Coming From Inside Vents. Had Heater Core Cleaned No Clog Found.erratic Display. Can Set Temp Controller To 90 Degrees Still No Heat.
01-01-06, 11:23 PM
Have you looked at your heater control valve?
01-04-06, 10:34 AM
Hello Johndfw.
Yes I Installed A New Heater Control Valve First. I Now Have Some Heat But Not Like When I Had No Problem.i Think I'm Going To Buy A New Bcm & Prom To See If This Will Work.
01-06-06, 10:44 AM
My BCM is not working either. The fan doesnt work at all. Replacing the BCM in your case might work. I'm not really sure how that thing works.
Good luck
01-06-06, 10:54 AM
What kind of Cadillac are we talking about, so I can move this to a better section for help?
