joeyblaze
12-25-05, 02:43 PM
Ok guys my GF bought a stock grill and is going to get it painted to match my body paint, The shops said there should be some sort of paint code labled on the car, The question at hand is where can i find this color code, i looked ll over the car with no luck
xcorpion1969
12-25-05, 03:03 PM
this might help a little with inding your color code http://www.automotivetouchup.com/choosecolor/choosecolor.aspx?year=2005&make=Cadillac&model=CTS or you can try this too http://www.paintscratch.com/col2003.htm which gives a diagram on where to look for your color code on your CTS.
joeyblaze
12-25-05, 04:29 PM
Thanks, it seems that our cts color code is on the spare tiure cover, they have a break down of a chevys stickers, im guessing our color code would be in the same spot since they are all GM's
joeyblaze
12-25-05, 05:51 PM
ok so this is the sticker on the back of spare tire cover, from readling the links above im guessing my color code has the U and L in it but i see a few dif codes with that
is mine 964 ?
http://img343.imageshack.us/img343/4755/colorcode8fq.png
xcorpion1969
12-25-05, 06:13 PM
Joey, yes....the 964 would be the code
joeyblaze
12-25-05, 06:33 PM
thanxs alot for the help bro :) ill post some picstures of my color matched grill
onephatguy
12-26-05, 05:15 AM
If you are not sure, you can have your service department give you the code.
ewill3rd
12-26-05, 07:49 AM
You have to tell them this
29U... that is the base color code
964L.... that is the process code, it tells them HOW to paint it to get the right finish.
With those two numbers they can paint anything. They must have them both however or you'll get a funky
variation of the base color. Most of the finishes out there are variants of a given base coat but the paint
process determines the final look of the parts.
The 3 digit that ends in U is called the "upper" paint code. They must have that one.
The code that ends with I is your interior trim color.
Another good info from the forum. Thanks guys.:thumbsup:
joeyblaze
12-26-05, 10:58 AM
thanks for the infor guys :) ill def post pics to reward you for your good info :)
