: FAO Mccombie - Phaeton Plant
EDGE Motorsport
12-23-05, 08:43 PM
Hi there,
I guess i should introduce myself so you dont all think im some random stalker ....
My name's Michael, I work with a guy who is a member of this board, he drives an STS. I remeber him talking about a guy on this forum that owns a Phaeton. I just found these pictures of the VW Phaeton Assembly plant in Germany and thought you might appreciate them.
I hope this is the right section to put these in... dont want to tread on any toes..
The Factory Itself
The factory is located directly beside the Dresden botanical garden, and VW has taken care to make sure the landscaping compliments the park beside it.
http://www.hostdub.com/albums/PanEuropean/Dresden_1.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_1&op=modload&name=Gallery&file=index&include=view_photo.php)
The glass building is especially attractive at dusk.
http://www.hostdub.com/albums/PanEuropean/Dresden_2.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_2&op=modload&name=Gallery&file=index&include=view_photo.php)
The factory is located at the intersection of Lennéstrasse and Stübelallee, and there is passenger tram service on both of these streets. If you walk in a north-west direction along Stübelallee for one mile, you will be right in the heart of the old city of Dresden. The name of Stübelallee changes several times as you walk along, but it is obvious that it is the same big, wide promenade.
http://www.hostdub.com/albums/PanEuropean/Dresden_3.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_3&op=modload&name=Gallery&file=index&include=view_photo.php)
But, that was not a normal passenger tram...
The tram in the photo above is actually the Volkswagen tram that brings parts from the logistics facility to the Transparent Factory. It looks quite a bit like a normal Dresden tram-car, but if you look at the side of it, you can see that it is a 'freighter', not a passenger tram.
http://www.hostdub.com/albums/PanEuropean/Cargo_Tram.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Cargo_Tram&op=modload&name=Gallery&file=index&include=view_photo.php)
The next two photos give you an idea of the architecture of the building. Yes, it is this clean, every day.
http://www.hostdub.com/albums/PanEuropean/Dresden_4.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_4&op=modload&name=Gallery&file=index&include=view_photo.php)
http://www.hostdub.com/albums/PanEuropean/Dresden_5.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_5&op=modload&name=Gallery&file=index&include=view_photo.php)
Arrival of the carosserie (body-structure)
The carosserie is built in Zwickau, about 60 miles from Dresden, in the same building as the Bentley Continental GT. It is painted there, and then transported to Dresden. This is more or less what it looks like when it arrives, before Phaeton assembly begins.
http://www.hostdub.com/albums/PanEuropean/Dresden_6.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_6&op=modload&name=Gallery&file=index&include=view_photo.php)
The fuselage-stuffing process
Each Phaeton is individually hand built. Sometimes two people work on the car at once, but more often, one person works by him or herself. Because each Phaeton is unique, all the parts and components needed to construct that specific car are picked ahead of time in the logistics center, and loaded onto storage modules. You can see two storage modules, there is one in front and one behind each car. The small square station in the right foreground contains specialized tools that are used to assemble the vehicle at that particular stage of its assembly.
http://www.hostdub.com/albums/PanEuropean/Dresden_65.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_65&op=modload&name=Gallery&file=index&include=view_photo.php)
Another view of the work area
The word 'assembly line' really doesn't seem to fit here, but there is a moving line. You can see the two tiny seams in the floor, on either side of the car. The portion of the floor inside those seams moves in a continuous loop throughout the work area. It moves very slowly, about the same speed as a revolving restaurant. You don't really notice the movement when you are inside the factory. The semi-circular arcs in the floor sections allow the entire section to slowly swivel to turn a corner.
http://www.hostdub.com/albums/PanEuropean/Assembly_Line.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Assembly_Line&op=modload&name=Gallery&file=index&include=view_photo.php)
Early in the 'stuffing' process.
This is a photo of a Klavierlack Black Phaeton, quite early in the build process. Some components have been installed, but work on the interior trim has not started. The running gear has not yet been installed.
http://www.hostdub.com/albums/PanEuropean/Dresden_7.jpg (http://www.hostdub.com/modules.php?full=1&set_albumName=PanEuropean&id=Dresden_7&op=modload&name=Gallery&file=index&include=view_photo.php)
EDGE Motorsport
12-23-05, 08:49 PM
Lifting the Phaeton
At some stages of the build process, it is easier to do the work if the car can be lifted up and moved around as needed. The overhead cranes lift the car up, using the same 4 points that the car normally rests on, and the employee can then move the vehicle around as he or she wants. The working environment in this assembly plant has been very carefully thought out - there is no comparison with other car manufacturing facilities.
http://www.hostdub.com/albums/PanEuropean/Dresden_8.jpg
Mating the body-structure and the running gear.
Once all the wiring, electronic components, and other necessary parts are installed into the carosserie, it is then time to mate the body-structure with the running gear. The running gear is also assembled by hand, and brought to the main production area by an elevator. Little magnetic sensors beneath the wood floor guide the cart that contains the running gear to the correct position beside the overhead crane.
http://www.hostdub.com/albums/PanEuropean/Dresden_9.jpg
A different view of this work area:
http://www.hostdub.com/albums/PanEuropean/factory_7.jpg
Aligning the carosserie and the running gear
This is the first stage of the mating process - to make sure everything is correctly lined up.
http://www.hostdub.com/albums/PanEuropean/Mate_1.jpg
The carosserie is lowered to a comfortable working height
Note that the little electrically powered cart that was holding the running gear in the photo above has now moved out of the way. These carts are quite sophisticated, and move to the correct locations on their own, once the craftspeople are finished with them and initiate the movement process.
http://www.hostdub.com/albums/PanEuropean/Mate_2.jpg
Attaching and connecting different parts
Now you can see the advantage of being able to keep the body-structure well above the floor.
http://www.hostdub.com/albums/PanEuropean/Mate_3.jpg
The running gear then moves up, once everything is aligned.
(Bet you thought the car was going to move down, right?)
http://www.hostdub.com/albums/PanEuropean/Mate_4.jpg
After the mating process
The Phaeton is starting to look a bit more like a finished car. The next major work will be installing the interior trim.
http://www.hostdub.com/albums/PanEuropean/Dresden_10.jpg
Moving to the next assembly area
Once the Phaeton is on the overhead crane assembly, it makes sense to leave it there until all the required work on the underside of the car has been completed. Once that is done, it will be placed back onto a workstand at surface level, as shown in the photos of the beginning of the process.
http://www.hostdub.com/albums/PanEuropean/Dresden_11.jpg
Final Visual Inspection
The interior has been installed, fluids added to the car, and the wheels and tires installed. The Phaeton is now moved into the light tunnel for a very thorough visual inspection. The next process after this will be testing the car, on both dynamometers and on the test-track underneath the factory.
http://www.hostdub.com/albums/PanEuropean/Dresden_12.jpg
And into the storage tower
EDGE Motorsport
12-23-05, 08:50 PM
Phaetons that are built for customers who plan to pick their car up at the factory are placed into the glass storage tower after they have been built, and the complete pre-delivery inspection process is completed. Phaetons that will be shipped overseas go to a different area, to be wrapped in protective packaging. The little courtyard area in the left foreground is part of the public area of the factory. Directly behind it, you can see the assembly areas.
http://www.hostdub.com/albums/PanEuropean/Storage.jpg
here's where all the info was originally.
http://forums.vwvortex.com/zerothread?id=1837641
if the mod's would rather delete the images from my post and just leave the link then that's cool... i dont want to come on here and cause all kinds of chaos :)
thanks,
EDGE
DBA-One
12-23-05, 09:03 PM
Wow. That is stunning. Of course, they could have sold the car for less had they skipped all that. On the other hand, if I were to take delivery of a high-end car from the factory I would be extremely impressed. Very cool indeed.
Kev
12-23-05, 09:05 PM
It certainly would make a nice field trip for the kiddies, though a bit impractical for us in the States. Looks too purdy to call it a factory!
DBA-One
12-23-05, 09:13 PM
The more I learn of the Pheaton the more I respect it. If I recalled correctly, VW has pulled the plug on it here in the US. Maybe they could try again but call it something other than a VW. The 80k VW is a very, very hard sell here. There are a couple around this area. They look great. Better still with nice wheels.
urbanski
12-23-05, 09:17 PM
dang!!! great pics, great thread, thanks!
Playdrv4me
12-23-05, 10:38 PM
Absolute Incredible... makes me want one of these terrific machines even more.
I~LUV~Caddys8792
12-23-05, 10:45 PM
wow that is amazing! and very german! Cleanliness!!
Jesda
12-24-05, 01:35 AM
If the service was as impressive as the manufacturing, it would have had a chance in the US.
SilverFleetwood85
12-24-05, 02:55 AM
I have seen the pictures before on the VW forum, but wow everytime I see them (the pictures) my respect for the Phaeton increases. It would be cool if Cadillacs were built in a plant that was as impressive as the Phaeton plant.
Caddy Man
12-24-05, 03:11 AM
so wait...the phaeton is hand built??? or is that some futuristic assembly line??? wow, i am very impressed, looks like its out of some wierd science fiction movie.
mccombie_5
12-24-05, 05:24 AM
Wow, some of thos epictures I havent seen before. I can see why it took them such an amount of time to do mine. I had the chance to go visit when the ca was finsihed back in September, but I couldnt go, I think I might be making a trip there now.
Instead of me collecting they put it in a covered transporter. BMW style. Rolls Royce style. Ferrari style.
