mcowden
12-22-05, 12:46 AM
I found a link to this information on Google, but the original article was no longer available. Thanks to the Google cache, the information was still available. To preserve it a bit longer and make it accessible to everyone here, the article text is below.
The Chemistry of Cooling Systems, Larry Carley, Underhood Service, October 1996
Ever wonder why thermostat housings, aluminum radiators, water pumps and cylinder heads become badly corroded? Why radiator hoses eat through from the inside out, or why radiators sometimes clog up with gunk? You'll find the answer in cooling system chemistry.
You don't need a Ph.D. in chemistry to appreciate the fact that the coolantcoolantcoolant that needs attention. In many cases, the stuff is loaded with rust and sediment and looks more like hot chocolate than coolant. But even when the coolant is still green and looks good as new, the corrosion-fighting additives are often found to be depleted when the coolant is tested. So don't judge the condition of the coolant by appearances alone - looks can be deceiving. in many vehicles today is badly neglected. Numerous surveys by manufacturers, aftermarket groups and even consumer organizations have found that about a third of all vehicles contain
If you test even further, you'll also find the concentration of antifreeze in the coolant varies wildly from the 50/50 mix recommended by most vehicle manufacturers. Out of every 12 vehicles, four on average either have too much water and not enough antifreeze, or too much antifreeze and not enough water. Another three or four may also be low on coolant.
One reason why the problem of coolant neglect is so rampant today is partly due to the fact that the average age of the U.S. vehicle fleet is well over nine years. Many vehicles have had only one or two coolant changes since they were new. And some are still pumping the same old tired coolant through their engines they had when they left the factory!
Coolant neglect also can be blamed on gas-and-go driving, extended service intervals and the elimination of many maintenance items that were once necessary to keep a vehicle in good running condition. Engines today no longer need annual tune-ups and few motorists see the need to winterize their vehicles. Consequently, many pay little or no attention to checking or changing the coolant until a problem occurs.
By the time you see these vehicles, the long-term effects of coolantcoolant.
neglect are usually self-evident - corroded and clogged radiators, eroded aluminum cylinder heads, water pumps and thermostat housings, rotten radiator hoses, leaky heater cores and freeze plugs - even blown head gaskets and chronic overheating. The root cause in most cases can be traced back to the poor condition of the
The Importance of the Mix
Though many people realize they need a certain amount of antifreeze in their cooling system to prevent the water from freezing during cold weather, many don't realize that antifreeze also helps prevent boilover during hot weather. Ethylene glycol, the main ingredient in conventional antifreeze, freezes at about 8 degrees F, boils at 330 degrees F and carries heat about 15 percent less efficiently than water.
Most vehicle manufacturers recommend a 50/50 mixture of antifreeze and water for optimum year-round protection. A 50/50 mix provides freezing protection down to minus 34 degrees F and boilover protection to 228 degrees F. Straight water obviously provides no freezing protection, no boilover protection beyond 212 degrees F, and no corrosion protection. Therefore, as you know, straight water should never be used in a cooling system. Straight ethylene glycol antifreeze also should never be used because it needs to be mixed with water (35 percent or more) to lower the solution's freezing point. Straight antifreeze also cools less efficiently than a mixture of antifreeze and water. Running straight antifreeze can raise metal operating temperatures inside an engine 70 to 80 degrees, which may be enough to cause galling problems in the exhaust valves. The maximum concentration of antifreeze should never exceed 65 percent.
Measuring the Mixture
The only way to know if the coolant is properly mixed is to measure the strength or concentration of antifreeze with a hydrometer, floating ball gauge, test strip or refractometer. Then, and only then, can you determine if more antifreeze or more water is needed. Simply opening the radiator cap and dumping in some extra antifreeze for added freezing protection may put too much antifreeze in the mixture. Exceeding an 80 percent concentration of antifreeze in the coolant can cause silicate gelling. The silicate corrosion inhibiting additives that are found in most "aluminum-safe" antifreezes can drop out of suspension, forming a gel or greenish goo that clogs the radiator and reduces heat transfer.
Even if the old coolant is drained out of the radiator and the system refilled with the proper 50/50 mix of antifreeze and water, the coolant may still not have the correct ratio. Up to a third of the old coolant can remain in the engine if only the radiator is drained. Unless this residual coolant is flushed out, it can dilute the fresh coolant as well as contaminate it with accumulated rust and sediment.
A thorough job of revitalizing the coolant, therefore, requires more than adding fresh antifreeze to the radiator or doing a simple drain and fill. It requires flushing the system to remove all traces of the old coolant, cleaning the cooling system if necessary to remove accumulated rust and scale, then refilling the cooling system with a properly balanced mixture of water and new or recycled antifreeze.
Chemical Breakdown
The "anti" part of antifreeze applies not only to freezing and boilover protection but also corrosion protection. A typical jug of antifreeze contains 96 percent ethylene glycol by weight, two percent corrosion inhibitors (silicates, phosphates and/or borates) and two percent water (a little water is necessary to help blend the inhibitors with the glycol).
Antifreeze formulated for aluminum engines typically contain a much higher concentration of silicates than that formulated for cast-iron engines. This can sometimes cause silica gelling problems if an antifreeze designed for passenger cars and light trucks ends up in a heavy-duty diesel truck engine. Heavy-duty trucks typically specify a low silicate formula antifreeze because they have mostly cast-iron engine parts and brass radiators. A supplemental additive that contains silicate is then added to the system to provide the required corrosion protection. But if there's already a high silicate antifreeze in the system, the coolant can become over saturated with silicate causing the silicate to react with itself and gel.
Silicate solubility also decreases as the ratio of antifreeze to water increases. In coolant that's accumulated a lot of miles, this isn't as much of a problem because much of the silicate will have been used up. But with fresh antifreeze and water, using too much antifreeze and not enough water may create conditions that are ripe for gelling.
Fighting Corrosion
The rate at which corrosion takes place inside a cooling system depends on a number of factors: the presence of minerals and other impurities in the coolant; the type of metals and alloys in the engine and radiator, and the acidity or alkalinity of the coolant itself.
Acidity and alkalinity is measured on a "pH" scale, where 7 is neutral, lower numbers represent increasing acidity and higher numbers increasing alkalinity (pH is chemist talk for the concentration of hydrogen ions in solution). Pure water is neutral with a pH of 7. Battery acid reads 2 or 3 on the pH scale, while baking soda might rate a 10 or 11.
Whether the coolant is acidic or alkaline makes a big difference. As long as it remains alkaline, corrosion is inhibited. But if it goes acidic, corrosion starts to eat away at the interior of the system. The corrosion-inhibiting additives in antifreeze are put there to keep the solution on the high side of the pH scale. The alkalinity of a typical antifreeze/water mixture will vary depending on the additives used and ratio of ingredients, but is usually somewhere between 8 and 11. The average for most antifreezes is around 10.5, but when diluted 50/50 with water and added to the cooling system the pH drops to the 8.5 to 9 range. Higher is not necessarily better, though, because some of the new long-life coolants have a pH of only 8.3. Staying power is what counts.
To ensure that the coolant remains alkaline for a reasonable length of time, there must be enough corrosion inhibitor to neutralize the acids formed from glycol degradation that occur over time. This neutralizing capability is called "reserve alkalinity," and it varies depending on the type and quantity of additives used in a particular brand of antifreeze.
Heat, dissolved oxygen, minerals in the water and corrosion inhibitor reactions at the metal surface gradually "use up" the corrosion inhibitors; once depleted, the coolant becomes acidic and corrosion accelerates. The trick to preventing internal corrosion, therefore, is to change the coolant before all the reserve alkalinity has been used up.
Under normal circumstances, conventional antifreeze usually contains enough reserve alkalinity and corrosion inhibitors to safely last two or three years. Replacing the antifreeze every two years or 30,000 miles for preventative maintenance, therefore, is usually recommended.
Periodic coolant changes are especially important with today's bi-metal engines and aluminum radiators because the different metals create a miniature battery cell that encourages electrolytic corrosion. Aluminum becomes the sacrificial anode, iron the cathode, with the coolant serving as the charge-carrying electrolyte. The higher the percentage of dissolved minerals and salts in the coolant, the better it conducts electricity and the faster the aluminum is eaten away. The corrosion inhibitors in quality antifreezes prevent this destructive electrolytic corrosion. But once the inhibitors are depleted, pinholes can form in radiators, cylinder heads can begin to weep coolant into the cylinders or crankcase, and water pumps and thermostat housings can start to leak.
Other problems can also accelerate the breakdown of the coolant. An exhaust leak into the cooling system through a cracked head or leaky gasket will quickly destroy reserve alkalinity because oxygen reacts with the additives in the antifreeze. If an engine has blown a head gasket, therefore, don't reuse the old antifreeze - replace it.
Using "hard" water can also shorten the life of the coolant. Tap water contains dissolved minerals that can react with and reduce the effectiveness of the corrosion inhibitors. Softened water contains fewer minerals but contains salts that can be just as bad. The best type of water to use, therefore, is pure distilled water. Distilled water is pH neutral, contains no acids, dissolved salts or minerals and will maximize the life of the coolant.
Chemical Breakdown
Fighting Corrosion
