Spyder
12-20-05, 03:38 PM
1984 GMC 3/4 ton. Disc front, drum rear. I had to get on the brakes hard the other night, and ever since then, the rear's have been locking up really bad with only a little pedal pressure. They look fine when the drums are off. The proportioning valve, I assume, is stuck or not working properly. Is it adjustable, because I don't see any way to adjust or bleed it. I called my dad and he said there should be a bleeder on it, but there isn't that I can see. There is a little rubber thing on the end like a primer for a lawn mower, but no adjustment screws or bleeder screws. Gonna try to bleed it by loosening the lines, hell, it can't get any worse than it is now...any ideas would be great! Thanks...
And this is non-caddy, so it should be alright here! :D
