Mojochiken
12-19-05, 08:53 AM
What is the bolt pattern for the rims?
Thanks
Thanks
| View Full Version : 79 Coupe Deville Rim Mojochiken 12-19-05, 08:53 AM What is the bolt pattern for the rims? Thanks pcm 12-19-05, 01:46 PM your 79 is 5 on 5 I'm pretty sure if that helps Mojochiken 12-20-05, 04:22 PM Is that the same as 5x127? Where can I find a set of steel rims?:confused: JTraik 12-24-05, 12:08 PM Is that the same as 5x127? Where can I find a set of steel rims?:confused: Where can't you find them, should be the real question. Go to the junkyard. Bro-Ham 12-24-05, 12:26 PM Hello! Is it true that the steel rims which fit locking wire wheel covers are different than the standard steel rims? Dave | |
