: Changing Spark Plugs- '99 STS
clusco
12-17-05, 06:35 PM
I am going to attempt to change my spark plugs and wires on my 99 Seville this weekend but I first wanted to know if it was a big job. What tools are best used (Indexible socket wrench and u-joint socket)?
Is it a pretty easy job?
danbuc
12-17-05, 06:41 PM
Yeah, it's a pretty easy job as long as you have the right tools. You'll need a metric socket set to remove the ingition module (with packs still attached). You'll also need a 6" extension and spark plug socket. I recommend running the new wires through the old looms before you put them in,s ince it can get kind of confusing. Try to change on at a time. New wires aren't numbered either, so you'll have to match them up by length to the old ones. Use a small Sharpie marker to number them once you've figred out which one is which. It's about a 1.5-2 hour job depending on how experienced you are.
CadillacSTS42005
12-17-05, 07:00 PM
make sure you replace them with platnum plugs or else!!!
Ranger
12-17-05, 08:44 PM
Be advised, ther are 2 hidden bolts on the backside of the ICM that require the Braile method to R & R.
clusco
12-18-05, 09:01 AM
Can I get these Platinum plugs at Autozone?
I also need new wires....what type should I get?
Ranger, you mentioned 2 more bolts to remove but in my service manual it doesn't mention anything about this, does this also pertain to my 1999 STS and if so can you go into detail about it a little more? Thanks
STS-in-Nottingham
12-18-05, 11:23 AM
Spark plugs:- AC Delco 41950
Wires:- AC Delco 748N
CadillacSTS42005
12-18-05, 02:30 PM
AC Delco you cant go wrong man!!!
Ranger
12-18-05, 06:08 PM
Well, I can't vouch for the '99 but, I suspect it is the same as my previous '97. Remove the obvious mounting bolts on the left and right side of the ICM. If it then lifts off, your in buisness. Mine would not come off. Upon further inspection I found two more mounting bolts on the back side (firewall side). As I mentioned, they were impossible to see. I had to get at them by feel, which made it a bit of a PITA. My daughter has a '99 and is supposed to be over a little later. I'll check hers and post back.
lembo
04-08-14, 08:26 PM
My 99 STS has the 2 rear hidden 10mm bolts on the ICM and the one on the passenger side has a ground wire under it.
