N0DIH
12-14-05, 01:21 AM
This post is primarily for informational purposes. I have done these mods, and they do work, but my combination was specific. Your results may vary! Modifying carbs is fun, but can be easily destructive. Have a parts carb handy! Modify the part on that one first if you are going to, then transfer it to the other carb. Most mods are not reversable! If you don't like it, you may be stuck with it. If you drill into a passage and go through, you may ruin your carb! Plan carefully. Mount things in a vise or clamp to a drill press to drill. By all means, get Doug Roe's book on Rochester Carburators. It is a MUST HAVE before you start to modify your carb.
Something I did on my 350 Olds, which was using a 307 ECM. Tune the Q-JET for WOT power. I found best power to be around .85 to .88v on the O2 sensor at WOT. I found that .92 and higher just seemed too rich and did nothing for power. Lower (leaner) voltage seemed to have a more crisp WOT power.
To do this you will need to connect a wire to the O2 sensor, and run it into the car, OR connect it to the O2 input at the ECM. Use the ECM ground.
Connect to a digital volt meter. Select the 2v scale. With engine cold, you will see a fixed voltage on the O2. Once you pass 3.5 minutes time since cold start, it will be fluxuating up and down fiarly quickly. But a stab at WOT will show it stops fluxating and goes to a fixed voltage. This is what the secondaries are flowing, as ECM cannot control the secondaries.
I have a boatload of metering rods that I used to tweak with. Honestly, I had ended up with a fairly fat rod on the secondaries, with the air flow of the secondaries allowed to go to WOT (yes boys and girls, the carb on a 307 WILL flow 800 CFM...) The carb is a vacuum secondary, so it will only flow what is needed. So let it have what it wants.
I used a H or earlier hangar, as I had that too. The rare and elusive "A" hangar was factory on the 1986 Astro van w/4.3 V6 if you are ever looking for one...
Ok, some other mods that I did....
Careful tweaks of the carb settings to 1985 HO 307 "9" specs gave great drivability. I also drilled 4 tiny holes in the secondary fuel feed tubes to allow for faster fuel pickup (as per Doug Roe's Q-Jet book, page 125), and the secondary feed holes moved to the above the secondary air doors (P.124).
I also drove down the internal secondary air bleeds to the recommended 1in depth to reduce the passage restriction when assembled (factory is 1.25", which is too far down).
I modified the accelerator pump circuit, (feared by some for loss of fuel economy, but I never lost any, and drivability was enhanced) bu shortening the fuel pump rod so that the pump would be higher in the bore, but not high enough that it would cavitate and allow fuel to pass the seal. If you need more seal thickness, the 2GC accelerator pump seal can be used. I actually cut around 3/16" of an inch off of the pump to get it in the right place in the bore! Many aftermarket pumps are pretty sloppily made. Heavy cars need more pump shot. This can also be accomplished very well with a new accelerator pump arm linkage that is much longer and have a new bend in it to allow for adjustability. I saw this on a 68 Ram Air II Firebird that ran 12.2's in SS/F. I also recommend finding a early 80's E4MC/E4ME carb that has the accelerator pump arm with the linkage closer to the piviot point. If yours is out at the end, you can drill a new hole farther in and relocate the arm location. You will need to readjust TPS when you have the pump dialed in.
Next I tweaked the point when the secondary throttle plates start to open. This is an area to be VERY careful, going a little too far here can make the secondaries open too early causing drivability problems (you don't want to cuise on the secondaries do you?. You need to carfully time this opening point with the ECM going into WOT mode. And you must make sure the secondary throttle blades do not open too far or not far enough, as this can lead to lean cyls, not even fuel distribution in the intake. You must get the book for these mods.
Also, as many have posted here on this site, adj the secondary opening rate. This has a big effect on the car. With this and the other mods listed above, the Q-Jet will be a very smooth, very powerful carbonator that will rival EFI for response and power.
Float level. 307 "Y" engines have a low float position compard to the "9" engine. I like the "9" position, as it decreases the transition times, so there is less a delay for the fuel to start moving. Too high can cause fuel to move when it is not ready to. A little goes a long way here.
