My 1994 Deville Concourse trans just stopped working. I was driving the overdrive stopped, then drive then nothing. All at once. I did not think the trans was bad so I had it towed home. I dropped the pan changed the filters, fluid, pan gasket, and tried it again. Sure enough I would get a couple of miles and it would do it again. I'd wait ten minutes, and the car would drive again only to do the same after a couple of miles. Can anyone please help me out with a suggestion?
OBDI should still give some indication of what's going on.
It sounds like it isn't the transmission itself when you could get it driving normally again but it could still be something in the transmisison and a costly repair.
Was the pan loaded?
If so, something is coming apart & the main filter in the side cover is probably clogged.
Related Threads
Cadillac Owners Forum
4.8M posts
370.4K members
Since 2002
