View Full Version : Now My Dad Thinks His STS Takes Regular Unleaded!!!
Chuck C
03-08-03, 12:26 AM
My dad has been putting regular gas in his car per advice of the salesperson! My bro is borrowing it at the moment, so I couldn't show him the "premium unleaded only" decals and owner's manual. I have a feeling that even if he sees that it says premium, he'll still put in regular (esp. since it's leased and gas $$ is sky high). I also tried to tell him that it says Premium Unleaded Only right in front of my face in my car! :banghead:
Help me to convince my dad that the salesperson was wrong and that his 2003 STS needs premium unleaded only. Also tell him why high Octane is so important in order for the Northstar to sustain a long life!
Devil_concours
03-08-03, 01:15 AM
in the new northstar engine, you are allowed to use regular gas unlike the older ones where it was required to use premium gas.
Chuck C
03-08-03, 01:38 AM
!!! did not know that
rek
03-08-03, 11:15 AM
Chuck, I think the higher output NS in the STS still requires Premium fuel....A Caddy sales rep told me that, but I haven't checked for sure. The price difference between 93 octane and the next lower grade is a dime a gallon here. SO, 20 gallons, is two bucks difference. No big deal. It's a CADILLAC . It will run on lower octane, but the spark timing will be changed, and less power will be made. Why buy a race horse, then feed him less then he needs? Premium has a slower burn rate. Some would argue that you will get better milage with premium, in a vehicle designed for it. Bottom line, use what the Factory says to use, they know a bit about their product. I have read that some gas, sold as 93 octane, is actually lower than 93. If they do that, how low would gas sold as 89 octane actually be?
AKPsiMC03
03-08-03, 12:53 PM
they lowered the compression on the the 02+ northstar which alows you to run regular. it used ot be 10.3:1 (i think) now its down to 10.0:1... so regular is good... all they did was reshap the combustion chamber on the heads.
87CoupeDeVille
03-08-03, 02:54 PM
The actual requirement for premium gas is now 92, gas stations can market it as premium as long as it meets that. I think 89 still needs to be 89.
Kurt
elwesso
03-08-03, 03:59 PM
What i do with my Q, i alternate every other tank. If i can remember, i put half of premium in it, and when it gets to half i top it off with mid grade. The octane requirement is 91.
Personally, i would put in premium. It will run so much smoother, and will get better gas mileage.
rek
03-08-03, 07:04 PM
http://www.mr2.com/TEXT/gasoline_faq.txt This place has one or two ideas about octane. http://www.gnttype.org/ this is where I got it. Explore the site, you'll find a good write up about home brew race gas mixture. Also, Rocket Fuel FAQ tells a tale about octane. Tech articles--- Misc.----Have fun!
Chuck C
03-08-03, 10:14 PM
so is anything less than 89 octane bad for the new northstars?
BeelzeBob
03-09-03, 12:42 AM
87 should even be fine.. The 2002 and newer Northstars run fine on 'regular' unleaded...
Chuck C
03-09-03, 02:40 AM
okay, good, that's what we filled it with today. BTW, I drove it for the first time today, and mannnn, what a great ride. Lincoln Continental (previous car)...a joke compared the STS!
elwesso
03-09-03, 09:04 AM
They will run fine, but they will run better on premium.
Devil_concours
03-09-03, 09:54 AM
all around performance(handling, accleration, braking, cornering) should be at another level than lincoln. Have fun and drive safely
elwesso
03-09-03, 10:04 AM
I do like the air suspension on the continentals. It keeps the rear level, and it feels like your riding on air, because you are! The only thing those are good for is highway cruising, and its not so good if your in the back seat!
jadcock
03-09-03, 10:04 AM
You can run regular gas in any Northstar. L37 vs. LD8 makes no difference. Up to 1995 (I think it was 1995), they all said premium REQUIRED. After 1995, they changed it to RECOMMENDED because of increased gasoline prices. The engines still run fine on regular gasoline. The engine is equipped with a spark retardation system in the event of spark knock. Since the engine was designed from the beginning to run premium gasoline, you'll get the best performance out of premium gasoline. If you run less than premium, you may get some spark knock; the spark timing would then be retarded and the knock will go away, at the expense of a few horsepower.
Starting in 2000, the engines were redesigned. The combusion chambers are completely different. The compression ratio is now down to 10:1 (versus 10.3:1 for the earlier heads). Cadillac recommends regular gas in 2000+ cars. Since the engine and computer system are now designed with regular gas in mind, there is no reason to run any higher octane, since there should be no spark knock with regular gas, and thus, no performance compromises with that gas.
michaelb
09-18-03, 04:53 PM
Fuel Grade Shell Game. Take a look at www.fueleconomy.gov for listing of the manufacturer's reported fuel grades for each model. Site is run by Department of Energy. You should also be able to view a hardcopy pamphlet at the dealership but it does not list all models. For example, the 2003 pamphlet shows Deville as using regular gas. So, GM is telling the Feds that regular gas is the design fuel, even when many can't get by on anything but premium or regular plus booster plus carbon cleaner. That's even if we use best source regular and travel hours at 70+ every week.
So, how can our reality differ so much from what the manufacturer certifies to the government?
jonrodman
09-18-03, 10:24 PM
Hi Chuck,
Does your father's STS have the Variable Valve Timing? There are a lot of advantages to the VVT. One of them is lower octane gas, another is more power, and a third is greater efficiciency.
Jon
rapid rabbit
09-18-03, 10:30 PM
My 2000 Esc uses regular. The fuel gauge decal calls for premium, but I was told to ignore it. It runs great.
Ralph
11-28-03, 01:19 AM
My dad was stupid and did that too, and then I noticed the engine knocking around 40 mph! Before I took delivery of the car I MADE him put in the PREMIUM that is REQUIRED for that engine! I was concerned there would be engine damage, as well as deformed sparkplug electrodes, there wasn't, thank God! He is hard of hearing and could not hear the knocking. Cadillacs are so well insulated for noise control, that you may very well NOT BE ABLE TO HEAR THE ENGINE DAMAGE OCCURING, so please, do yourself a favor and put in PREMIUM. I may as well just saved you thousands in repairs. Learn from other people's stupid mistakes.
trackersrus
03-31-06, 01:11 PM
my 01 eldo etc requires only regular fuel. runs great steve
233,000 miles and counting
mtflight
03-31-06, 03:01 PM
Congratulations Steve.
How long have u had your Eldo?
AlBundy
03-31-06, 06:34 PM
My 96Eldo runs fine on regular as well.
Eldobroken
04-03-06, 06:09 AM
Sold my 94 Touring Coupe with 172K runnning perfect but always used premium and synthetic oil. Now my 2000 ETC does not have premium sticker but I use only premium. Why screw around with a 6000-8000 dollar engine for a few bucks. BTW Premium burns slower. This was very previlent when I raced mustangs and had an MSD adjustable timing controller in the car. Regular got me 8 Degrees of advance without pinging and super got me between 17 and 19 degrees of advance before pinging. Which BTW can put a hole in your pistons.
peteski
04-04-06, 02:42 AM
These "regular" vs. "premum" fuel threads are becoming as frequent and as annoying as the "dino" vs. "synth" oil threads!
Very silly! Can't we just tell people to search the archives as this subject has already been beaten to death?
I have been running my 93 N* on regular for about a year now.
Peteski
mtflight
04-04-06, 08:35 AM
Peteski
I hear ya. This was an old thread (almost 3 years old) resurrected because a new member was searching the archives. So why it may be annoying to some folks that have heard the question asked over and over throughout their tenureship here, it was new to someone else.
The archives haven't worked very well for me, with the new Google search engine. I hope it's a glitch that will be corrected.
Chuck C
04-28-06, 11:54 PM
I know, that new google search stinks. BTW, I've learned a ton since I started this thread over 3 years ago!!
Ranger
04-29-06, 11:47 AM
The search has been fixed and google is gone. You may now resume searching. Enjoy.
fpmesiIII
04-29-06, 09:26 PM
yay google is gone, that was brutal. but concerning the octane. regular (87) is fine for ANY northstar engine.
