: MAF Sensor
12-07-05, 12:15 PM
How critical is it if I don't change this part right away. 400 dollar part wow...Will there be any side effects....Thanks
12-07-05, 03:10 PM
I just replaced my mass air flow sensor and i got the part from the Caddy dealer for only 187 dollars so I would shop around also you will burn a ton of fuel if you do not replace it also you may burn up your O2 sensors with all the extra fuel going into it.
12-07-05, 03:18 PM
Which dealer is selling this part for 187....I'll love to give them a call. The two dealership close to me in PA is telling me 444 bucks. Thanks for the info though about the gas consumption.
12-07-05, 03:31 PM
any GM dealer should only charge you 187 bucks for the part if you are going to install it.
12-08-05, 12:21 AM
That is not a factual observation. Have you been to any GM dealership yet?
12-09-05, 12:04 PM
yes i called the local dealers in my area when I had to replace mine and they all quoted me the same price. also you can buy it from gmpartsdirect.com they will charge you 97.06 plus the shipping will cost a little more. the part number for the mass air flow sensor is 90528435. and my catera is a 1999.
12-10-05, 02:43 AM
That probably is why your MAF is cheaper, it's for the 1999 model. I am not sure, but i am thinking that the one for the 1997-98 model is a lot more expensive
12-10-05, 04:08 PM
I have just made a check with GMParts direct and i didn't see any 97 dollar Mass Airflow Sensor. Are you describing another sensor? And in fact, the one that is for the 99 model came out more expensive than that of the 97-98. I guess you can provide us a link to the site you are mentioning because if it comes out to be true, then that's a very good price.
12-10-05, 07:46 PM
well call your gm dealership and ask them if part number 90528435 is a mass air flow sensor for a catera and they will tell you yes it is cause it is the one I bought for my catera and it works fine. So go to gmpartsdirect.com and enter the part number I gave you and it will come up for 97 bucks if you want I will scan my darn receipt so you will under stand that you can get the part for 97 bucks. besides I am here to help other catera owners get parts cheap. cause we all need to save money because we drop a fortune on these darn cars.
12-10-05, 07:52 PM
0
check out your
wish list order
status your
Advanced Search FAQ View Cart Register Request a Return Customer Service GM Warranty E-Mail Us Tell a Friend Home
Search Results of Available Items
*Prices are Per Unit
Page 1: 1-1 of 1 items
GM PART # 90528435
CATEGORY: Computer Control Sensors
GM LIST: $194.13
OUR PRICE: $97.06
NOTE: GMPartsDirect.com carries 380,000 GM parts. Due to the number of parts available, the part you are searching for may not appear in these results. Please use our Customer Service page if you need help locating a GM part. Can’t find a part?
^ Back to Top ^
Performance Parts | Restoration Parts | GM Accessories | GM Merchandise | Specials | Vehicle Care | Wheels | Links
Advanced Search | FAQ | View Cart | Request a Return | Customer Service | GM Warranty | E-Mail Us | Tell a Friend | Site Map | Home
©2004 - Flow Chevrolet, LLC - All Rights Reserved. GMPartsDirect.com is independently owned and operated by Flow Chevrolet, LLC,
an authorized independent reseller of General Motors Parts. This site is not owned or operated by General Motors Corporation.
Privacy Statement | Site Policies | Warranty Disclaimer
12-10-05, 07:52 PM
that is the price and part number for the 99-01 catera
12-11-05, 03:13 AM
I was making my check through the Catalog section and the part number for the 99-01 Mass Airflow Sensor in the Catalog section came out different from the one you posted here. Actually, there are two part numbers available for the 99-01 Mass Airflow sensor and both did not tally with the one you posted. And the description of the both part numbers is "Air Flow Sensor". Somebody here could probably clarify on this. Well, if the sensor you got is working for your car then you should have the right part. This is weird because I did the search like you said and the price you posted checked out, but why is it called "Computer Control Sensor"?
12-11-05, 08:42 AM
well there catalog has the wrong numbers because from the start page if you look up the one part number 9193533 it is not a valid number then the other number 93171760 comes up also as a computer control sensor. if you read the disclaimer it even tells you that they can not promise their part numbers are right. so the best thing to do is call your dealer and get the most current part number then search for it right from the main page on their site because they change part numbers every so often don't ask me why. but they do. so you can verify my claim by calling your gm dealer and the part number is 90528435 is for the 99-01 catera I don't know about the 97-98 but it will save you a bunch of money.
12-12-05, 01:00 PM
Do you know if the 99 maf will fit in a 98. I'm calling the dealers and they are telling me that they are not allowed to give out part numbers so I can't verify the numbers you posted. ??? why is it called "Computer Control Sensor"? and not the MAF sensor.
12-12-05, 01:46 PM
I called my local dealer who was nice enough to give me the part# which is 19137087 they sell it for $426.68 but you can get it from gmpartsdirect.com for $213.34 and it is a type of computer control sensor because your car runs like crap because maf sensor controls the fuel injection system. but when you unplug it the car goes into a default mode. it will burn more gas. but I am 100% sure that is the right part number that I got from my dealer for the 97-98 catera so I would order the part from gmpartsdirect.com for the $213.34
12-12-05, 04:07 PM
Thanks so much again bengsxr....I'll get it from the gm website
12-12-05, 05:45 PM
no problem always glad to give help when I know what I am talking about because I too need help from others on the wesite here.
12-11-08, 03:46 AM
I thank you. :highfive: You saved me money and no doubt many others too. The gm site's search feature could use an overhaul.
12-27-08, 02:01 AM
as for finding MAF's sensors. i had mine out of the car and pulled the actual sensor out of the tube and did a search for the bosch # of F00C 2G2 030 thats on the meter. alttle searching and many numbers later, went looking on ebay and found the similar numbers from supplier's and asked if they carry this particular sensor. one VW seller had 3 on stock as new assembly for 125.00 us delivered to western canada. i little time and searching can and will find anything new and cheaper than any GM dealers will ever let out the door.
01-02-09, 02:41 AM
I just bought a 99 Catera for my son. It drove good for one day and then the Check Engine light started coming on. We noticed the transmission is slow to shift from 1st to 2nd. We also noticed that the power steering is now very tight and hard to turn. I think these could be related, but I'm no mechanic.
He took it to Auto Zone who tested it and the Code p1700 came up. Any help with this would be deeply appreciated. I cannot afford to take the car to the dealer, especially if this something that could be fixed relatively easily.
ps...I checked all the fuses and they all were good.
Could this be a problem with the MAF?
01-02-09, 11:51 AM
P1700 - Transmission Control Module (TCM) Requested MIL Illumination
Does not sound good. Not sure how to address this...
01-07-09, 08:49 PM
I recently just stepped into a Catera. Got my 99 Sport at a great price. However it runs ruff at idle. Also it breaks up all over bank 2 under heavy loads. The idling issue I be leave is the MAF sensor. Under its data stream the sensor has feedback but is reading 0.00 g/s and No fluctuation with Revolutions. My misfire acts up more intermittent. Im hoping the MAF will correct both problems. What do you guys think? I bought this car off a customer so all the cars history is available very easily. Did I mention the car has had only one owner before me. And this guy owned the car for 150K. I think she still has plenty of life. Especially the was this elder man took care of it. As far as the history goes I have noticed all coils have been replaced within the past 35k miles along with the spark plugs. How are these cars with compression loss?
