View Full Version : Our Instrument Cluster Repair Portfolio
mrwhizard
12-16-03, 08:22 AM
Electronic/Digital Instrument Clusters We Repair
Go ahead and browse the following list for the types of instrument clusters,climate control units, digital clocks and touchscreen units we repair. They are grouped by manufacturer. If you don't see yours, feel free to call us Toll Free 1 888 803 8523 with your specific requirements.
Visit http://www.mrwhizard.com (http://www.mrwhizard.com) for more info.
General Motors Instrument Clusters
1989-94 Blazer/Jimmy/S-Series/Bravada/Sonoma/Tahoe - Symptoms: Dark, Intermittent, Smoking, Burning Smell, Missing Sections, Odometer is Dark, Missing Segments or displays "Error".
1988-93 Oldsmobile Cutlass Supreme - Symptoms: Dark, Intermittent, Odometer jitters, Odometer displays "Error".
1988-93 Oldsmobile Toronado (Trofeo) Analog Dash - Symptoms: Information Center dark - only tachometer functions. Climate Control malfunctions.Your climate control system is not at fault - remove instrument cluster and climate control functions should return to normal. If "Electrical Problem" is displayed in the Vehicle Information Center in the instrument cluster; there may be other faults in the vehicle; please call us for more details.
1986-up Oldsmobile Toronado Full Digital Dash- Symptoms: Totally dark or intermittent, flashing, all displays except Information Center/tach Dark. If "Electrical Problem" is displayed in the Vehicle Information Center in the instrument cluster; there may be other faults in the vehicle; please call us for more details.
1989-90 Oldsmobile 88 - Symptoms: Totally dark or intermittent.
1986-87 Olds Cutlass Ciera - Symptoms: Intermittent or dark.
1990-91 Cadillac Brougham - Symptoms: Digital display is intermittent or dark.
1989-94 Chevy Astro, GMC Safari Van - Symptoms: Dark, Intermittent, Garbled Display, Odometer non functional or missing segments.
1994-1996 Chevrolet Caprice - Digital Speedometer/Odometer dark or dim, odometer erratic.
1994-1996 Chevrolet Impala - Digital Speedometer/Odometer dark or dim, odometer erratic.
1986-89 Chevy Cavalier Z24 Digital Dash - Symptoms: Dark, Intermittent. Analog tach works OK.
1999-2000 Chevrolet Cavalier - Digital Odometer dim or erratic.
1988-90 Chevy Beretta - Symptoms: May Start Ok but strange characters; Fuel, Temp display on left shows bars on top half of range.
1984-89 Chevy Corvette - Symptoms: Intermittent or Dark. Sorry we cannot repair Corvette clusters where the displays are "sunburnt". A normal cluster display should look black when the vehicle is off. If it is sunburnt you will see color through the display(s).
1988-89 Pontiac Grand Prix - Symptoms: No or intermittent odometer or other displays, missing segments, no speedometer reading (stays at 0), Oil/Temp lights come on intermittently. No digital display backlighting unless parking or headlights on.
1991 Pontiac Grand Prix - Symptoms: Low Fuel and Check Gauges indicator lights on when they should not be. May be intermittent.
1992-93 Pontiac Grand Prix - Symptoms: Analog Odometer (rolling type) does not work.
1993 Pontiac Grand AM - Symptoms: Intermittent speedometer or oil light or other indicator lights on when they should not be.
1998 Pontiac Sunfire - Symptoms: Odometer does not work or stuck in trip or odometer mode.
1985 Buick Century Digital Dash - Symptoms: Dark or intermittent display.
1985 Buick Regal Digital Dash - Symptoms: Dark or all displays show fluctuating characters.
1990-92 Buick Regal - Symptoms: Analog Odometer Does not Work.
1990-93 Buick Riviera - Symptoms: Dark or intermittent display. Tach goes to 0 and then "00" and "Error" is displayed.
1990-93 Buick Reatta - Symptoms: Dark or intermittent display. Tach goes to 0 and then "00" and "Error" is displayed.
1987 Buick Skylark Digital Dash - Symptoms: Dead or intermittent.
1986 Buick Somerset Digital Dash - Symptoms: Dead
Dodge/Chrysler Instrument Clusters
1995-up Dodge/Plymouth Neon - Symptoms: Intermittent speedometer and other gauges.
1996 and UP Chrysler Sebring - Symptoms: No odometer OR no odometer and tachometer.
1996 and UP Chrysler Sirrus - Symptoms: No odometer OR no odometer and tachometer.
1996 and UP Dodge Stratus - Symptoms: No odometer OR no odometer and tachometer.
1986 Chrysler New Yorker Digital Dash - Dark main display - trip/information display on left works OK.
Lexus Instrument Clusters
1993-94 Lexus LS400 - Symptoms: No backlighting or backlighting slow to come on.
Mercedes-Benz Instrument Clusters
1991 Mercedes-Benz 500SL - Symptoms: No gauges, clock works OK.
Nissan Instrument Clusters
1989-93 Maxima Digital Dash - Symptoms: Dark, may come on when warm and/or speedo and odometer not working. OR, Temp and Fuel gauge works but speedo/odometer/tach gauges are dark.
Climate Control Units
1997-98 Buick Century - Symptoms: Heater/Climate Control unit digital display is dim, dark or intermittent.
1999 Buick Regal - Symptoms: Heater/Climate Control unit digital display is dim, dark or intermittent.
1989-94 Olds Cutlass - Symptoms: Dark Display or does opposite of what it should - causes Heat when its warm outside and cool when its cold outside.
1989-93 Olds 88 - Symptoms: Dark Display or does opposite of what it should - causes Heat when its warm outside and cool when its cold outside.
1989-93 Nissan Maxima - Symptoms: Electronic Climate Control dim, intermittent or non-functional.
Digital Clocks
1989-93 Nissan Maxima - Symptoms: Digital display is dim, dark or intermittent.
Touchscreen Units
1989 Buick Riviera (other models/years)- Symptoms: Intermittent, dark, makes fizzing sound, functions still work (you just can see it!)
Note: On the above units; other model years may apply - call us if you don't see your specific year.
Call our Toll free Number 1-888-803-8523 if you have any questions or to make shipping arrangements.
