View Full Version : HID light kit
fast66
12-03-05, 02:08 PM
Since my front lights broke I have been trying to replace them, I want a philips HID conversion kit for 9006 sized bulb. I found this what do you all think?
http://cgi.ebay.com/ebaymotors/NEW-Philips-HELLA-H1-H4-H7-9006-9007-HID-Xenon-Kit-OEM_W0QQcmdZViewItemQQcategoryZ36476QQitemZ8017623 372QQrdZ1
is this really philips?
also if you know of any other places that i could buy this, I would appreciate it, Thanks
clickart
12-03-05, 09:02 PM
I got a kit from www.xenondepot.com 6000k. It works and looks great! It is really easy to install. Just plug and play. I dont think he has it in stock now. So email before you order.
hcvone
12-05-05, 08:27 AM
You have to be careful, the first auction that ended Dec 4th were Phillips, the others that are listed are GTEC. I have purchased many different brands over the past ten years, the only bulbs and ballasts I have had any luck with are Phillips or Hella. The most light output is 4300, that is what stock HID output is on new cars. Here are a few that sell them.
http://www.xenonpros.com/philips4300k.html
http://www.xenondepot.com/product.php?product_id=8
http://www.xenonking.com/philips_4300.htm
womsterr
12-05-05, 10:52 AM
You should also try Gary at www.x-metal.com
He has the full assortment and the best pricing I have seen!
fast66
12-05-05, 04:22 PM
Thanks for the info guys,
I appreciate it
Also my headlights are broken,
Coudl I buy this and put it in my 02 Escalade?
It is a 03 Headlight with the phillips ballast
http://cgi.ebay.com/ebaymotors/CADILLAC-ESCALADE-HEADLAMP-HEADLIGHT-LAMP-LIGHT-HEAD_W0QQcmdZViewItemQQcategoryZ33710QQitemZ802026 9299QQrdZ1
Super
12-05-05, 05:16 PM
you will need some new wiring in order to get it working since your truck doesnīt have HIDīs
csmooth79
12-05-05, 08:12 PM
Is 4300k what comes factory in the escalade?
I see some of the kits have a bixenon high+low beam. Does this mean there are two xenon bulbs and two ballasts. So could you effectively have xenon low beam and fog lights?
Super
12-06-05, 06:50 AM
Yes, 4300K is from factory.
A true bixenon setup uses the same bulb for high/low beam.
hcvone
12-06-05, 07:48 AM
As said 4300k is what factory HID bulbs are. I have HID low beams (stock) I have added HID high beams, and I have HID fogs too, so yes I have a ballast for each light, 6 ballasts. On my 03' all four lights (high beams and low beams) are on when using the high beams, I have to say it's like day time. ;)
fast66
12-06-05, 02:54 PM
I could do the wiring myself
thanks
fast66
12-06-05, 02:56 PM
how did you get the fogs to stay on with the high beams?
hcvone
12-06-05, 04:18 PM
The fogs do not stay on with the high beams, they are on with the low beams, when the high beams are on the low beams are on also, so all four headlights are on with the high beams.
hcvone
12-06-05, 04:21 PM
thanks
You can probably do the wiring yourself, most of the HID kits are plug and play. :)
