View Full Version : Removing dash trim panels... I'm going to be installing a Parrot CK3100 Bluetooth Car Kit in my uncle's SRX tomorrow and I was wondering if anyone had some pointers on getting at the stereo. Specifically removing the dash pieces.
Is it a tough job or is it mostly clips?
Any info would be appreciated.
-Jason caddysrx 12-01-05, 11:51 PM I recently removed my bose radio to install an FM realtime traffic receiver I bought to connect to my Garmin GPS. I asked my local Caddy dealer's service advisor if they would install it for me but he said they normally do not install aftermarket products. He was nice enough to print out the instructions for removing the radio from the GM service website, which is password protected. I have scanned the instructions (for the purpose of emailing to a friend who thought he could do it for me, but I eventually did it myself) and attached the pdf file below. You need to first remove the top center air vent cover. I didn't unplug the hazard light wire, I just rested the vent cover on the dashboard. Next you need to remove the plastic ashtray cover and remove the screw - all screws have hex heads. I also did not fully disconnect the HVAC assembly. You just need enough space to expose the 4 radio screws. I used the back part (claw?) of a hammer to remove the air vent cover and HVAC assembly, since it fit in the very narrow gap between the cover and the dash. I was very careful in doing so and I probably sweated off a couple of pounds in the process. The antenna plug is in the back right side of the radio. I believe the antenna plug is an ISO. Good luck. Let me know how it turns out.
***I tried to upload the pdf file but it exceeds the limit allowed by the forum. If you reply with your email address, I would be happy to send it to you that way. robhersch 12-02-05, 12:51 AM CaddySRX,
Read the above; although I did not make the request for help, I also would appreciate your emailing me the .pdf file to >>robhersch@juno.com<<
Thanks in advance. robhersch --2005 SRX N* V8 RWD, Blue Chip/Ebony-- Same here, I have an '04 SRX and I just bought the nav system from an '04 SRX, I'm gonna try to swap for my 8 speaker bose system. I'd really appreciate the instructions too. my addy is: mbarnz@yahoo.com. Thanks! -mike r_casino 12-02-05, 10:18 AM Sounds similar to the CTS....maybe this'll help:
http://www.cadillacfaq.com/faq/answers/radbezel.html I recently removed my bose radio to install an FM realtime traffic receiver I bought to connect to my Garmin GPS. I asked my local Caddy dealer's service advisor if they would install it for me but he said they normally do not install aftermarket products. He was nice enough to print out the instructions for removing the radio from the GM service website, which is password protected. I have scanned the instructions (for the purpose of emailing to a friend who thought he could do it for me, but I eventually did it myself) and attached the pdf file below. You need to first remove the top center air vent cover. I didn't unplug the hazard light wire, I just rested the vent cover on the dashboard. Next you need to remove the plastic ashtray cover and remove the screw - all screws have hex heads. I also did not fully disconnect the HVAC assembly. You just need enough space to expose the 4 radio screws. I used the back part (claw?) of a hammer to remove the air vent cover and HVAC assembly, since it fit in the very narrow gap between the cover and the dash. I was very careful in doing so and I probably sweated off a couple of pounds in the process. The antenna plug is in the back right side of the radio. I believe the antenna plug is an ISO. Good luck. Let me know how it turns out.
Thank you, I really appreciate the help.
You can send it to deleted
I'll let everyone know how it goes... caddysrx 12-02-05, 01:05 PM Thank you, I really appreciate the help.
You can send it to esales@nepminc.com
I received an undelivered do not have proper authentication message for the email I sent to you. I attempted from both of my email accounts. Do you have an alternate email address such as hotmail, yahoo, etc? I received an undelivered do not have proper authentication message for the email I sent to you. I attempted from both of my email accounts. Do you have an alternate email address such as hotmail, yahoo, etc?
Yeah, sorry about that, our email at work is down today.
You can send it to jjd_che@yahoo.com
Thanks again,
-Jason ewill3rd 12-02-05, 05:51 PM It's exactly the same process as CTS.
The screw behind the ashtray has a 7mm head, or 9/32".
The screws that hold the radio in are 10mm head.
It's easy in a sense but sometimes the spring clips on the HVAC control put up a fight.
I use a small pocket screwdriver under the corner on the passenger's side at the bottom of the unit. If you turn the key on and pull the shifter to the bottom you have extra room to pull the control out but set the park brake first so you don't roll.
The vent pops out pretty easily, if you just turn it upside down and lay it on the top of the dash you don't have to disconnect the wires, which if you have tried you realize is a major pain. caddysrx 12-02-05, 08:49 PM I followed the same approach in removing my radio as you had mentioned. I had to do it twice. I installed an FM TMC traffic receiver that connects between the antenna and the radio and sends realtime traffic updates to my garmin GPS. Both sets of cables that garmin provided were not compatible with the SRX radio (which I discovered after I removed the radio the first time), despite that one of the sets is designed for GM radios. I checked garmin's website for additional resources and there was a picture of a 3rd set of cables (ISO) that looked like the set that matched the SRX radio. The website indicated that those set of cables are included with the units that they ship to UK and European customers. After speaking to their customer service they mailed the proper set of cables to me and I suggested to them that they include those cables to USA customers as well. Removing the center console and radio went a little bit more smoothly the second time. I didn't know if there was a specific tool used to pry the vent cover and HVAC unit from the clips, but I used the claw of a hammer and prayed that I wouldn't damage anything. dietermod 12-03-05, 12:24 PM :bouncy: You are a saint. PLEASE send me one @ dietermod@aol.com. Thank you.:worship: Well, this is a very informative thread. Thanks to everyone for contributing! Well, I was able to open up the radio/NAV system fairly easily. Some of the spring clips were a little tough, but overall it wasn't too bad.
Now, the next problem. I'm going to make a custom harness to install this hands free kit, but I can't find any wiring information for the SRX. I've looked around and there seems to be plenty of info on CTS wiring, but it's not the same as the SRX wiring. There is a 32-pin, 20-pin, 16-pin, 5-pin and 1-pin connector back there. I mapped out the wire colors, but I don't have any info on what the different color wires do. Is there any info out there on SRX radio/NAV wiring? jjdche, there is a thread pretty high up in this forum (rear seat entertainment sound or some such title) that has the pinout for the radio.
A question: I seem to remember hearing that if you removed the plastic ashtray insert, you could get to an antenna connection. Is this true? If so, I'd like to install an FM modulator there. If not, do I have to take out the whole radio or is there a better way? ewill3rd 12-19-05, 09:47 PM Hmmm, I think there is a coax connection behind the ashtray.
Let me double check.
Here is a picture of the CTS dash, number 1 should be a good coax connection to tie in a modulator. The one on the back of the radio is kind of a strange connector and probably wouldn't work.
Looks like it's on the right side of the console. You might be able to access it by just pulling the carpet back on the side of the console. Yeah, that's perfect. I would want to tie in the modulator right there. Taking the ashtray off is no problem, it's probably preferable to pulling back the carpet. thanks ewill! ewill3rd 12-20-05, 05:57 PM I looked at one today. You can do it either way. The carpet just pulls back quite easily actually, but if you need to get in there...
remove the coin tray and there is a hole in the center, there's a 7mm screw in there, then the whole hvac control and ash tray come out together.
I think it was noted above but I just wanted to say it again.
It's right there, I had my hands on one today. Another question: is it easy to get to the cupholder area from back behind the ashtray? If so, I'll put the on/off switch for the FM modulator in there (and maybe the whole installation).
While I'm asking questions, where would be the best place to attach 12v power to the modulator? Is it better to splice into the cigarette lighter power, or should/can I run the wire to the fusebox?
Thanks for your help, ewill3rd! I appreciate it. ewill3rd 12-25-05, 12:40 PM Switched ignition feeds are hard to find these days.
Maybe I can find a place for you to get Retained Accessory power or something. You have to be careful about connections that are designed to be "key on" feeds because if you hook them into B+ they can drain the battery.
Remind me later and I'll see what I can find for a power tap.
The center console comes out in just a few minutes. The only hard part is getting the shifter trimplate off. Otherwise it's just 6 bolts and you lift it up.
I am sure if you had it off you'd find all sorts of access underneath.
You want fused power feeds but you don't really want to tie into the fuse boxes. It can ruin stuff.
More later Thanks again! Seems like powering the modulator will be hard. I know that it only requires a single power lead, not two. It has one wire for power and the other is for grounding. Is it okay just to splice into the cigarette lighter's power? That would be the most convenient power source.
Another idea I had was to run all of the power outlets to the rear seats - for example, install a 1-to-2 socket adapter (plugged in under the rear-seat entertainment thing), place that under the shifter area, and plug the XM radio and FM modulator into that. This way I wouldn't even need to splice anything and it would be easy to get power. In the end, I'd like to place the XM radio mounted in the ashtray assembly and have the fm modulator underneath the console or behind the HVAC/ashtray piece.
Could you give me more detail on removing the center console area? For example, where are the six bolts?
Thanks so much! ewill3rd 12-26-05, 08:14 AM Move the seats forward, there should be some plugs covering the bolts at the rear of the console.
Take those off and remove the screws in the back.
Then move the seats back and pull back the carpet on both sides of the front console, it's kind of a pain but not too bad.
There are two more screws (one on each side) in the front of the console.
You might remove the shifter trimplate before you take out the screws.
It's kind of hard, but carefully get some sort of tool under one of the corners and pry up, do it on the side towards the rear. When you get that lifted it should just come right off. You'll have to turn the key on, press down on the brake and shift the car into gear, get an assistant to help you lift the console up over the shifter and unhook any connectors, I think there are 2 major ones. The one on the left I think is gray and kind of hard to see, but with the carpet pulled back get your head down under the driver's dash and you should see it up in the center area sort of behind the radio panel. On the right side I think is a green one that is easier to spot. You just push in on the tab (squeeze) and it should unhook and come off. There may be one small connector left to unhook but I don't recall.
You might set the parking brake just in case your foot comes off the brake while you are working. Just lift up the rear of the console and slide it back to get room to lift the front and take it out the back.
It's not that hard really.
If you start tying in electronics be careful not to overload the circuit with devices. The wires are only rated to handle so much current.
Depending on when your car was built using the cigar lighter outlet might have strange results. I know they did something to enable a 10 minute timer after you turn off the key for these outlets. You might have to move the fuses to keep it hot at all times, or you might have to move them if you want it on the 10 minute timer circuit. There is a bulletin on this feature but it's hard to decipher.
It all boils down to the requirements of the device you want to hook up. MortnCyn 12-26-05, 09:26 AM ....If you start tying in electronics be careful not to overload the circuit with devices. The wires are only rated to handle so much current.
Do a search for 88953222. That is the part number involved regarding changing the 10 minute circuit timer. I had tried moving fuses to get mine to work on the '04 and could not get it to work. Gave the dealer the part nimber required and he admitted that they could not find, at that time, a tech bulletin on the problem. I have not tried moving fuses on the '05 yet. I do know the power stays on because I have an adapter that has a light that is on when it is plugged in. Thanks for all your help, guys. Hopefully my install will be a success. | |
