RAMAIR57
12-14-03, 02:48 AM
I have a 2000 ram air t/a and it has sealed lube points, so I never have to get it lubed. Are there lube points on the deville, and if so, where? also,how often should this be done?
| View Full Version : Lube points on a 92 deville? RAMAIR57 12-14-03, 02:48 AM I have a 2000 ram air t/a and it has sealed lube points, so I never have to get it lubed. Are there lube points on the deville, and if so, where? also,how often should this be done? Ralph 12-14-03, 04:24 AM Be sure to check your rear end! Because there are 4 grease nipples back there! :histeric: Seriously! DaveSmed 12-14-03, 01:53 PM Well put Ralph. :rolleyes: I think the ball joints and tie rod ends also have zerk fittings. Check your sway bar bushings, as sometimes they have fittings too. | |
