View Full Version : any advice would be helpful
yeloboi
11-27-05, 07:33 AM
My check tire pressure mes. keeps coming on. I have 24's and have checked my pressure numerous times and it's good. The yello warning light in the dash is on also. I didn't put the sensors on the new wheels by the way...... any help would be apreciated...
8ball
11-27-05, 07:40 AM
I think you just answered your own question....you didn't install the sensors in the new wheels. Mine comes on too everytime I start the vehicle, just reset it but I don't get a yellow warning so have no idea why that happens. I would put the sensors in but my wheels came with mounted tires already so I'll just wait till I have to buy tires.
womsterr
11-27-05, 10:41 AM
Is this a trick question?
terrible one
11-27-05, 12:29 PM
lol yeah man it's because you didn't put the sensors in
yeloboi
11-27-05, 04:51 PM
This isn't a trick quest. I'm aware of the tire monitor message. I've had my 24's for about 8 months and that comes on when you first start the truck but about a week ago the check tire pres. message came on, also the dash indicator light comes on. Does this happen to everyone? I can turn the mes. off with the dic, but the dash indicator is vexing me. I guess i will take it to the dealership and see what they have to say....
Sky High Ent.
11-27-05, 04:56 PM
I was gonna pick up some 24's today. So does this mean , there is some kind of sensor that needs to be transfered to my new wheels?
where exactly are they located?
Thanks
yeloboi
11-27-05, 05:15 PM
They are located on your stock wheels where you put the air in. look at the valve stem and you will see it.
Sky High Ent.
11-27-05, 05:21 PM
I don't have the stock wheels on, but I never get a low pressure light, so I just figured they're on already. I'll check it out.
Thanks .
By the way if anyone wants a pair of 22" wheels with near new tires. Let me know. They're pictured below. They have the caddy emblem on them. Look factory.
Thanks
yeloboi
11-27-05, 05:27 PM
It would be on the after market wheels also. If you get a message on the dic about service tire then you don't have them on.
ewill3rd
11-27-05, 09:06 PM
The valve stem IS the sensor. You just can't see the part that is inside.
If you put on some bling you have to transfer the sensors to the new wheels or get used to looking at the light.
Tire Pressure Monitors (TPM) are going to be standard equipment for all carmakers. I think I heard for '06? Anyone?
dnyce617
11-27-05, 09:58 PM
There's no way to get the message off without putting the sensors on. You can reset the system and get the indicator light off, but it will come back after awhile. If you want to get it back to where it just has the message on startup,
1. Depress parking brake.
2. Turn ignition to run (but dont start.)
3. Turn headlight switch from all the way off to all the way on until your horn sounds (I think it's four times.)
4. Turn off ignition and start as normal
This should take away the warning light temporarily, but if you want to get rid of the error permanently you have to install the sensors.
yeloboi
11-28-05, 07:02 AM
Thanks........ That's what i was looking for. I wonder why it takes so long for the in dash warning light to come on?????? Ok so my next Question is with aftermarket wheels do i have to wait until i buy new tires or can they put the sensors on with the wheels i already have?
ewill3rd
11-28-05, 07:09 AM
You can put the sensors in the wheels.... provided there is clearance inside the wheel for the body of the sensor... and provided the thickness of the metal is correct to allow for proper installation.
Sometimes the shops leave them out because they won't fit on certain aftermarket wheels.
Years ago they were color coded for each wheel location and strapped onto the inside of the rim. That's on the old C4 Corvettes.
No programming was needed but tire rotations and changing sensors and installing two orange ones was always a hoot!
I like the programmable ones.
It's much easier.
hcox10
11-28-05, 08:30 PM
hi
how much do you want for the 4 22 inch wheels and tires.
will they fit a 2000 lade.
thanks haroldbfrog@comcast.net
jordan00escalade
12-03-05, 12:54 AM
hey it's joe.. I found your rims on craigslist and forwarded you an email. Guess someone beat me to the punch. LOL* I wanted those tires too.. :banghead: I didn't realize you were a member of the forums.
Thanks .
Thanks
Sky High Ent.
12-03-05, 03:09 AM
Yeah, I just sold them 2 days ago. I even put them on the classifieds here.
Nobody replied for a few days , but someone ended up driving up from the bay area to get them.
:D
