View Full Version : Help, I need a power steering pump.
Jimbad
11-24-05, 12:08 PM
(I'm hope that I am on the proper forum.) I'm looking for a power steering pump off of a '93 or '94 Northstar engine for my Eldorado. I'm not sure when but some time after these years the low-pressure fitting on the reservoir became forward-facing (it points toward the front of the car). This is the what I have on my replacement pumppresently and I have had to jerry-rig the existing hose to make it reach the nipple. I want the original one where the fitting on the reservoir for the rubber hose comes out facing the side of the car. I have tried local yards as well as Internet-generated yards and have had zero success. I'm hoping that someone here has one that they would sell to me.
MOST IMPORTANTLY: I do not need a working pump,all I really want is the correct reservoir, so I'll buy anything with said reservoir.
Thanks,
Jim
Hason560
11-25-05, 11:43 AM
i belive i have what you are looking for but i need a little better description or a picture if you can get one since im not sure how your pump mounts. the one i have has a little platic tube sticking out of\s the side of the resovior at a slight upward angle let me know if this is what you mean.
tony99sls
11-26-05, 10:46 AM
is this what you need? napa #20-53881
tony99sls
11-26-05, 10:51 AM
or this one? napa # 20-45881
Hason560
11-26-05, 11:25 AM
i have the one in the first pic sitting right in front of me. a1 cardon #20-53881 i belive its a reman
tony99sls
11-26-05, 11:30 AM
i think he needs the second one . napa part number 20-45881 that for a 93 eldo. I use napa numbers cause i work there . Same as A-1 Cardone. The 20-53881 is for a 94 eldo.And yes its a reman
Hason560
11-26-05, 12:13 PM
yeah i work at tyhe parts house in gainesville florida, at work right now actully lol. i think he need the first one cuase he said it has the hose pointing off to the side of the car
mcowden
11-26-05, 01:21 PM
I think the A1-Cardone 20-45881 part is what he needs for a 93 ETC, and yes it is a remanufactured pump. It goes for $81 at www.rockauto.com. Also possible is AC-Delco (OEM) part number 36516240 for the pump without the fluid reservoir or AC-Delco number 36516362 that does include the reservoir. I found the Delcos for $72 and $80, respectively, also at www.rockauto.com. The only thing I can find on www.gmpartsdirect.com is a "power steering pump assembly" for $267. Their catalog system really sucks.
I see now that he only really needs the reservoir. I can't find one listed separately anywhere. You might have to call a salvage yard. I've bought parts before from Fierge Auto Parts in Quincy, Illinois and they were good to work with. I'm not sure if they'd have what you need or not, but you can contact them at www.fierge.com or 1-800-252-9025.
Jimbad
11-26-05, 08:59 PM
Hi, Thanks for taking the time to respond, but no, that is the "wrong" PS reservoir.
Jim
Jimbad
11-26-05, 09:00 PM
Yes, Tony, the NAPA one is the one that I need.
Jimbad
11-26-05, 09:02 PM
Hason, thanks for the reply, but I need the tube to come out of the front of the reservoir, not the side.
Jim
Jimbad
11-26-05, 09:09 PM
Thanks to all who took the time to write, and even send pics (!). I do need the PS reservoir on which the plastic tube comes out the FRONT, not the side. Since I put a brand new GM pump ($285.00) on the car, but with the "wrong" reservoir, I'd like to fine a used one rather than spend $81.00 or so at NAPA.
Jim
