View Full Version : does anyone know how to take off a steering wheel?
starfox86
11-24-05, 11:56 AM
im trying to replace my steering wheel with a woodgrain one i bought. I have no idea how to even start.I know theres a couple screws undernieth and 2 in the back. anyone know?
jadz
11-24-05, 12:15 PM
The first step and most important is to remove SAFELY the airbag. Incorrect removal of airbags can cause serious harm. Please do a search for airbag removal. It will include disconnecting the batter and letting the car sit for at least 15 minutes, making sure not to have any static buildup etc.
Usually there are 4 bolts on the back of the steeringwheel that will release the airbag. Once the airbag is removed you will see one main bolt that holds on the steering wheel (under where the airbag was). You will need to undo this bolt and then use a puller to pull off the steering wheel.
starfox86
11-24-05, 12:35 PM
from what i can see, there are only two star screws behind the steering wheel. i took those out...but that only lets the back plastic piece wiggle. I'll search on how to remove the air bag. oh, this is in the 2000 seville..
Trench
11-24-05, 03:12 PM
Here are some PDF files I made from the AllData Website. I hope they help!
Dustin
Ranger
11-24-05, 05:27 PM
I just removed the air bag on my daughters '99 SLS to replace one of the steering wheel switches. You do not need the "special tool". It can be done with a flat bladed screw driver one at a time. BE SURE TO PULL THE AIR BAG FUSE FROM THE FUSE BLOCK UNDER THE REAR SEAT FIRST.
starfox86
11-24-05, 06:25 PM
thanks Trench for those pdfs .....I got it off and the new one on. Looks awesome! mmm, wood! lol....yeah i didn't use the tool either. Ranger , your daughter and you have both have an sls?...right on! Thanks guys.
iametarq
11-24-05, 08:04 PM
We don't need the special tool on the Seville? I needed it for my buick.
Ranger
11-24-05, 09:24 PM
Yeah, I had a '97 Deville and she had a Ford "Snarus" (first car after college). It was just over 100K and starting to have issues so we started looking. Being a Caddy man, I naturally looked that way but she wasn't exactly thrilled with the idea of a "granny car". I found a '99 SLS with 23K on it. We looked at it and she, somewhat reluctantly negotiated a very good price (made the ole man proud). The rest is history. One day she was getting on the expressway and some Mustang was trying to ace her out. Well, she kicked the ole Northstar in the ass and dusted him off. She immediately called me and when I answered the phone she said "Dad, I love this car". I think I have a convert. Well, the more I saw it, the more I liked it and I started looking. I found my '02 with 13K on it in Canton OH. via the internet (something I never thought I'd do). Called the dealer, made and offer and the next day I was airborne. And then there were two.Now I have to start working on daughter number two.
iametarq
11-24-05, 10:42 PM
Is pulling that fuse for the airbag sufficient to disable the SIR's system? if all i need is a flat headed screw driver to remove the steering wheel i might take a stab at it one of these days to replace my buttons and steering wheel.
I assumed i needed that special tool since I also needed for my buick.
thanks for your insight.
Ranger
11-24-05, 11:28 PM
It worked for me.
Closet Boy
11-25-05, 12:15 AM
This applies to my 97 STS, a late production date:
I replaced my steering wheel from an 02 Eldo several months ago. Purchased it on eBay for a bill. Gentleman was out of Canada. Was in mint condition.
Rented a puller from a local Murphy's Auto Parts. Pretty straight forward. R&R air bag. Pull wheel. Install.
ewill3rd
11-25-05, 07:07 AM
There are capactitors inside the SDM that store reserve energy to ignite the bags in the event of a collision with a loss of voltage.
Disconnecting the battery and pulling the fuse allows this stored voltage to dissipate.
It would still require a very unlikely set of circumstances to deploy the bag regardless, but you should always follow published safety procedures while servicing airbag related components.
I have handled thousands of them without incident. I have heard many horror stories but never seen any "accidents" first hand.
Closet Boy
11-25-05, 11:24 PM
I FORGOT TO MENTION....DISCONNECT BATTERY and FUSE as ewill3rd has stated. Also, when handling air bag, treat it like a LOADED GUN. Face it away from you during your limited transport. Set it down in an open area.
Do not sit in the front seat (facing bag) while re-installing...secure those bolts from the side of the steering wheel assembly. Run your codes when installed, sitting on the passenger side.
Should be gravy. Let us know how it turned out. Cheers!
ewill3rd
11-26-05, 09:22 AM
Technically you are supposed to disconnect the connector at the base of the column for the driver's side and the connector under the dash on the right side as well as unhooking the battery and pulling the fuse.
In the event of something happening to the harness.
starfox86
11-26-05, 07:07 PM
yeah.....saying I didn't use the tool did'nt mean it was easy....lol....It was thanksgiving day I replaced it and forgeting that stores were closed I couldn't get the puller...I ended up drilling 1/4 holes in the old steering wheel around the middle till it broke off..then, I yanked it off with some vise grips. (never want to do it again)....I had somewhere to go that night..so I had to get it done. I do not have a working horn now although I am not concerned about it. never used it anyways... I took the negitive and positive off of the battery and nothing went wrong. I noticed when I took the rear seat off that there was about 5 bucks worth of change in it. lol.
Ranger..about the second daughter, give the one that has the 99' your 02' and give the 99' to the other daughter. and you get yourself a deserved 05' cadillac. cts-v :) gotta love em'
DBA-One
11-26-05, 10:18 PM
I've done this more than once. I've got a steering wheel removal kit and a huge ass torque wrench (so uselfull!). Just disconnect that neg battery cable first. Don't want that airbag blowing up in your face.
91TexasSeville
11-27-05, 01:12 PM
I have removed airbags from many different vehicles, but am still a lilttle nervous about doing it.
If you were not going to save the old wheel, you could have used a deadblow hammer to the back side of the spokes. Saves on drilling!
