Caddy01DTS
11-21-05, 11:39 AM
Does anyone have a list of the interior bulb types on an 01 dts? Thanks.
| View Full Version : interior lights Caddy01DTS 11-21-05, 11:39 AM Does anyone have a list of the interior bulb types on an 01 dts? Thanks. 1998Deville 11-21-05, 12:03 PM Do a search of the forums for Owners Manual, and you can download an owners manual for your car. The bulbs should all be listed in it. JeffS_76 11-21-05, 12:08 PM I use this site as a resource whenever I'm looking for a replacement bulb: http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/ Hope it helps. Caddy01DTS 11-21-05, 12:17 PM Thanks. Now, does anyone know how to get the cover off? Right rear dome light. BTW, I searched my owner's manual and didn't find anything about courtesy lights in the rear. Anyone know what size or type I need, and how to get the cover off without breaking it? The button is stuck in for some reason. Caddy01DTS 11-22-05, 11:20 AM Anyone? SurferTom 11-24-05, 11:35 PM Can't post images but this may help. 1st is Bulb replacement, 2nd is the switch <H1>Courtesy Lamp Replacement - Rear Quarter <A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=462209&psdid=226&evc=sm#ss1-462209">Removal Procedure http://127.0.0.1:9001/servlets/TifToGif?pic=294842 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=294842) <LI type=1>With a flat bladed tool, carefully pull on the outboard edge of the courtesy lamp bezel in order to release the two courtesy lamp bezel clips from the courtesy lamp bezel. <LI type=1>Rotate the rear courtesy lamp switch counter clockwise in order to release the rear courtesy lamp switch from the bezel. <LI type=1>Remove the courtesy lamp bezel. Remove the courtesy lamp bulb from the courtesy lamp fixture.<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=462209&psdid=226&evc=sm#ss2-462209">Installation Procedure http://127.0.0.1:9001/servlets/TifToGif?pic=657852 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=657852) <LI type=1>Install the courtesy lamp bulb in the bulb fixture. <LI type=1>Install the courtesy lamp switch to the courtesy lamp bezel. <LI type=1>Rotate the lamp switch in order to position the courtesy lamp switch wiring facing the outboard side of the courtesy lamp switch bezel. <LI type=1>Hook the inboard edge of the courtesy lamp bezel to the inboard edge of the headliner. Align the courtesy lamp bezel clips to the bulb fixture and snap the courtesy lamp bezel into place in order to engage the trim clips on the bezel.</H1>Courtesy Lamp Switch Replacement - Rear Quarter <A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=707883&psdid=226&evc=sm#ss1-707883">Removal Procedure http://127.0.0.1:9001/servlets/TifToGif?pic=702898 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=702898) <LI type=1>Remove the windshield pillar garnish molding. Refer to Garnish Molding Replacement - Windshield Pillar (http://127.0.0.1:9001/servlets/CellHandler?CellId=51678&RefDoc=707883&evc=sm) in Interior Trim. <LI type=1>Remove the center pillar garnish molding. Refer to Garnish Molding Replacement - Center Pillar (http://127.0.0.1:9001/servlets/CellHandler?CellId=51628&RefDoc=707883&evc=sm) in Interior Trim. <LI type=1>Remove the sail panel. Refer to Sail Panel Replacement (http://127.0.0.1:9001/servlets/CellHandler?CellId=51666&RefDoc=707883&evc=sm) in Interior Trim. <LI type=1>Remove the assist handle. Refer to Assist Handle Replacement (http://127.0.0.1:9001/servlets/CellHandler?CellId=51594&RefDoc=707883&evc=sm) in Interior Trim. Notice Use care when removing or installing the headliner. Excessive bending will damage the headliner. <LI type=1>Lower the headliner in order to access the rear quarter lamp electrical connector (1). Important The electrical connector for the rear interior lamp is glued to the headliner. The electrical connector will need to reattached to the headliner, after repairs are completed, in order to ensure the connector does not rattle. <LI type=1>Carefully release the electrical connector (1) from the headliner. <LI type=1>Disconnect the rear quarter lamp electrical connector (1). http://127.0.0.1:9001/servlets/TifToGif?pic=294842 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=294842) <LI type=1>Carefully pull on the outboard edge of the rear quarter lamp bezel in order to release the two quarter lamp bezel clips. http://127.0.0.1:9001/servlets/TifToGif?pic=702905 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=702905) <LI type=1>Rotate the rear quarter lamp switch (1) counter clockwise in order to release the rear quarter lamp switch from the lamp bezel (2). Remove the quarter lamp switch (1).<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=707883&psdid=226&evc=sm#ss2-707883">Installation Procedure http://127.0.0.1:9001/servlets/TifToGif?pic=702905 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=702905) <LI type=1>Install the rear quarter lamp switch (1) to the rear quarter lamp bezel (2). <LI type=1>Rotate the rear quarter lamp switch (1) in order to position the rear quarter lamp switch wiring facing the outboard side of the quarter lamp switch bezel (2). <LI type=1>Install the rear quarter lamp switch button to the rear quarter lamp assembly. <LI type=1>Hook the inboard edge of the rear quarter lamp bezel (2) to the inboard edge of the headliner. <LI type=1>Align the rear quarter lamp bezel clips to the bulb fixture and snap the rear quarter lamp bezel (2) into place in order to engage the trim clips. http://127.0.0.1:9001/servlets/TifToGif?pic=702898 http://127.0.0.1:9001/tif.gif (http://127.0.0.1:9001/servlets/RetrieveTif?pic=702898) <LI type=1>Connect the rear quarter lamp switch (2) electrical connector (1). Important The electrical connector will need to be reattached to the headliner, after repairs are completed, in order to ensure the electrical connector does not rattle. <LI type=1>Reattach the electrical connector (1) to the headliner. <LI type=1>Install the assist handle. Refer to Assist Handle Replacement (http://127.0.0.1:9001/servlets/CellHandler?CellId=51594&RefDoc=707883&evc=sm) in Interior Trim. <LI type=1>Install the sail panel. Refer to Sail Panel Replacement (http://127.0.0.1:9001/servlets/CellHandler?CellId=51666&RefDoc=707883&evc=sm) in Interior Trim. <LI type=1>Install the center pillar garnish molding. Refer to Garnish Molding Replacement - Center Pillar (http://127.0.0.1:9001/servlets/CellHandler?CellId=51628&RefDoc=707883&evc=sm) in Interior Trim. Install the windshield pillar garnish molding. Refer to Garnish Molding Replacement - Windshield Pillar (http://127.0.0.1:9001/servlets/CellHandler?CellId=51678&RefDoc=707883&evc=sm) in Interior Trim. SurferTom 11-24-05, 11:46 PM No info on lamp types Caddy01DTS 11-25-05, 12:39 PM Thanks a million for the info, SurferTom.. | |
