View Full Version : Auto dim side Mirror-Broken
locosteelersfan
11-19-05, 06:24 PM
On my 96. I never noticed that it dimmed before but now it is
stuck dim from the bottom up about 85% to the top. No big deal except that where the transition between normal and dim there is about a 1.5" smudge running the length of the mirror horizontally.
Anyone know whats going on?
Ranger
11-19-05, 07:21 PM
The mirror is shot and needs to be replaced to cure the "smudge".
crestviewpb
11-19-05, 07:22 PM
That happened to mine also, the fluid in the mirror leaks out. I found a used one at a place called go-go auto parts, found them from a search of the web. They were great to deal with and I found one already painted the color of my car I think for 35.00.
locosteelersfan
11-19-05, 11:37 PM
So I'd need to replace the whole unit. Great, I'm sure there's a ton of
light green metallic's around. There's about 5 other issues to address first.
Ranger
11-19-05, 11:57 PM
If you can't find the right color, you could probably do a pretty good job with a spray can of touch up paint. Having said that, I think the glass alone may be replacable. I'd try that route first. maybe a junkyard mirror and just swap the glass.
