Crypt0nite
11-19-05, 03:23 AM
How do I get the codes from my car when I get a service engine soon light? Any help would be appreciated
| View Full Version : How to get codes from a service engine soon light Crypt0nite 11-19-05, 03:23 AM How do I get the codes from my car when I get a service engine soon light? Any help would be appreciated I'm_macdaddy 11-19-05, 06:47 AM What is the year of the deville in question? Crypt0nite 11-19-05, 10:03 AM 92 Deville ElDawgg 2G 11-19-05, 10:22 AM Hello... Press the "Off" and "Warmer" buttons on the AC The codes will appear in the fuel gauge DIC. There are several types of codes "E", "EE", "EO", and "F". (current, history, etc) Press "Off" and "Higher" to clear Press "Auto" to exit Crypt0nite 11-19-05, 10:32 AM Thanks man..and is there a page or anything that explains what the codes mean? Kev 11-19-05, 10:47 AM Yes there is; http://www.cadillacforums.com/forums/showthread.php?t=21558 You can also do a Google search for OBD1 codes if you like. ElDawgg 2G 11-19-05, 10:48 AM Hello... http://myweb.accessus.net/~090/dtcobd1.html Crypt0nite 11-19-05, 11:42 AM I got these codes F46 - Low Refrigerant Charge F47 - Low Refrigerant Charge E90 - VCC Brake (http://www.cadillacforums.com/forums/showthread.php?t=21558#) Switch Signal Problem What do I have to do to fix these? And what exactly are both of those? (Im not a genius when it comes to cars lol) ElDawgg 2G 11-19-05, 11:59 AM Hello... Refrigerant can be added by any qualified service center, however, they first must check the system for leaks, and fix them, before adding. It is unlawful to add freon to a leaking system. The VCC code is related to your transmission. I have never had code E90... These problems can sometimes be difficult to isolate, as the transmission is complex. There are switches and solenoids inside of the transmission and you will have to drop it to R+R. Are there any driveability issues? It may be that the VCC (Viscous Clutch Converter) isn't receiving the signal to either turn on/off. There is a test you can perform to see if the VCC turns on/off. (apply the brake lightly while driving above 45(?) and you can feel the VCC turn on/off) Use the search feature to find out more details. Usually you will not notice when the VCC engages/disengages. (you will only notice a slight increase in RPM's and 1%-2% lower MPG's). Post back your solution. Crypt0nite 11-19-05, 01:01 PM Well..I know how to change the coolant..and I didnt get that VCC code again..and for some reason, my check engine soon light disappeared after I added a little bit of water cuz I didnt have any anti freeze..but I just got some and Im about to change it. I think my car is leaking anti freeze though | |
