View Full Version : Catera Heater problem
imageres
11-18-05, 12:44 AM
I have a 1998 Catera that is giving me heater problems. On the drivers side there is plenty of heat - the blower works well and the air is well heated. However, on the passenger side the blower works great but the air is very cold. I have the shop manuals but find that without the shop test equipment they don't do much good. Can anyone tell me hos to start on this problem? Winter is just getting started here and it tends to last a long time therefore a good heater system is manditory.
Thanks Doug
Cat-a-Tonic
11-18-05, 12:57 AM
What happens when you split the heat controls and set the passenger side temperature setpoint up to max? Do you hear the passanger side heater mixing valve motor ticking to an different position?
blaze 1 4 brame-o
11-18-05, 01:00 AM
My 97 Cat is the exact opposite...well heated on the passenger side but I freeze as the driver...this doesn't make sense
imageres
11-18-05, 01:09 AM
I have not tried to hear the valve but will give it a shot in the morning.
Thanks Doug
AllenPacla
11-18-05, 01:46 AM
Do a search in this forum and you'll find a lot of usefull discussion about this problem. Goodluck
97cateraowner
11-18-05, 10:01 AM
Try: http://www.cadillacforums.com/forums/showthread.php?t=55961
