nick111173
11-16-05, 08:16 AM
Help
my hood release cable poped. i would like to replace it but I can't open the hood. I have tried pulling on the wire it's self but had no luck. I reoved the front grill but i have no idea on what to do next. Any one had this problem before?
nick111173
11-16-05, 08:28 AM
The hood latch release cable on my '90 Deville snapped and I am haveing A hell of a time getting under the hood. i have removed the grill but i have no clue on what to do next. Help any one....
Please tell us the year and model of your car, that will help. if you have removed your grille and can get to the latch it should be just a matter of finding the point of connection of the cable and manually activating it.
Sounds easier than it may turn out to be I'm sure.
Good luck and let us know how you make out.
DaveSmed
11-16-05, 12:16 PM
Ugh what a project... If you can look at one in the junkyard, it might help you find where the cable is run in your car. IIRC, the latch is BEHIND the rad support, which really hinders access. You might actually have better luck going from under the car.
ElDawgg 2G
11-16-05, 06:22 PM
Hello...
:yeah: I recommend a visit to your local Pull-A-Part yard so you can disect a hood latch there.
It won't be easy, but it can be done.
I was successful by going in from underneath (car on ramps)
when I repaired a sticky latch on my 1989 Fleetwood.
Patience...and a good flashlight are your best friends!
Other than this, I don't have any further suggestions.
Post back your solution.
