View Full Version : Remote wire for aftermarket amp
Dadillac
11-15-05, 05:23 PM
This may sound like a stupid question, but I would rather know for sure, than feel dumb later. Hopefully, i will be installing a new amp, this weekend. In regards to the remote wire. Can I tap into the HU remote wire? Seems simple enough to me. If no, please explain why. Thanks in advance.
Don
B Hoth
11-15-05, 11:37 PM
I found it's safer to take the amp with you to an install location. I've found that they usually will give you the correct answer to that question.
JC316
11-15-05, 11:59 PM
Yeah, you can tap off from the HU remote wire. I usually hook a switch up to a constant hot and send it to the amp so I can turn it one when ever I want. You can also hook it up to any power wire that comes on with the accessories, if you want it to come on with the key. If you want it to come on with the HU, you would tap either the remote wire, or the power antenna wire. Your choice. Any of the above will work.
Dadillac
11-16-05, 05:53 PM
Thanks. I figured it was going to be okay. The install kit came today. The amp and sub are to arrive on Friday. As long as they come, I will be attacking this on Saturday.
Don
