View Full Version : Throttle body bolt torque specs
eldorado1
11-07-05, 06:58 PM
'96... what are the specs for the throttle body and throttle body spacer?
My book lists 106 inch-lb for the TB, but doesn't list the spacer to manifold torque?? :confused:
mcowden
11-07-05, 07:26 PM
1.21 gigawatts. And if that doesn't work, try 42. :thumbsup:
eldorado1
11-07-05, 08:14 PM
42. :thumbsup:
But what's the question? :bonkers:
eldorado1
11-08-05, 12:35 PM
So, nobody has a manual for a 96-99? Or you just can't find the spacer to manifold specs either??
mcowden
11-08-05, 01:19 PM
I moved in June and haven't seen my FSM since... If I can dig it out of the garage somewhere, I'll look it up and let you know today.
Ranger
11-08-05, 02:18 PM
Per the '99 manual.
Spacer 106 lb. in.
Throttle body:
Upper bolts 106 lb. in.
lower bolts 89 lb. in.
mcowden
11-08-05, 02:51 PM
Per the '99 manual.
Spacer 106 lb. in.
Throttle body:
Drat! Foiled again!!! :D
eldorado1
11-08-05, 02:53 PM
Per the '99 manual.
Spacer 106 lb. in.
Throttle body:
Why are the upper bolts different from the lower bolts???
Ranger
11-08-05, 03:12 PM
BTSOM. My thoughts exactly.
eldorado1
11-08-05, 03:54 PM
Hmm... I could understand if they were a different length, but they're not..
Maybe I'll just tighten everything to 89 in-lbs... This wouldn't be the first time I massaged the torque specs to prevent problems - I installed the intake manifold with 75in-lb instead of the recommended 89, due to a problem with the last install cracking the intake.
