View Full Version : Tighten those nuts and bolts!
heavymetals
11-06-05, 02:52 AM
After checking for the third time and finding the header stud nuts loose, I used a little bit of a high temp adhesive on the tips (like glyptol).
I would recomend that everyone who has installed headers recheck the nuts if you replaced the bolts with studs like the ARP 12 point type.
Joey'sVee
11-06-05, 03:02 AM
For all of us that don't know can you tell us more specifically what we should use...Link?
heavymetals
11-06-05, 03:10 AM
3501 SCOTCHWELD.
This stuff is like J&B weld.
I just put a dab to secure the nut to the tip of the stud that protrudes.
If you have to remove it you have to use a heat gun (not a hair dryer) to get the stuff to break down, but it will under very high heat.
Joey'sVee
11-06-05, 09:58 AM
Damn...don't know if I want a heat gun to be required if I need to remove/change the headers, ya know?
Closer_2001
11-06-05, 10:01 AM
3501 SCOTCHWELD.
Since these bolts are touching one of the hottest parts on the car...perhaps this won't last long term? How about a dab of Hi Temp RTV.
Rey
11-06-05, 10:24 AM
My experience with JB Weld is that it breaks down with heat. Seems to me that the exhaust manifold heat is high enough to break down JB Weld and Locktite.
I have had TPIS headers now for 20K miles, using stock fasteners and original gasket with no loosening whatsoever.
heavymetals
11-06-05, 12:19 PM
The temperature that the header bolt gets is not enough to break down the polyimide adhesive.
The header studs I am talking about are the ARP 12 points as they don't use a lock washer, but a flat one.
I would be curious to know how many people check and find that they have a couple of the nuts either loose or backed out.:eek:
willsctsv
11-06-05, 06:59 PM
No leaks or loosening up from my header bolts and I stayed with the stock ones. Go figure?
Vdrenaline
11-06-05, 10:38 PM
There is a company that makes locking header bolts. I have them on my Vette. Stage 8 maybe? Just do a google for Locking header bolts and you will find them.
CTSVONFIRE
11-07-05, 08:53 AM
I removed the studs in my headers b/c I kept getting an exhaust leak and replaced them with some nuts&bolts.
