View Full Version : Low Oil Pressure Stop Engine !
frankmarks05
11-05-05, 11:50 PM
I JUST GO A 2000 DEVILLE DROVE IT ABOUTH 5 MILES THEN THE BELLS AND CLUSTER SAYS STOP ENGINE LOW OIL PRESSURE ? CAN ANYONE HELP ...
IT WAS A QUT LOW WILL THAT MAKE THE CAR GO NUTS? I TOOK THE OIL CAP OFF IT SEEMS TO BE PUMPING OIL FINE .:hmm: i topped it off but only drove it a few miles no lights yet . i did find out it's been on the dealers lot for 2 years and it hasn't been drivein , a im going to change the oil and see what happins,,,,,,,,,,,,,,,, ok just changed the oil drove it for 10 miles nutting came up ? like i said the car was setting for 2 years at a dealership . it has 72000 miles engine purs like a kat? oh i did take it to a drivetrue car wash that sraywashes under the car do you guys think maybee that can do something?
Supercrew632
11-06-05, 12:51 AM
top it off and then see what it says----You probably have a major crankcase leak---have it checked..........
Supercrew632
91TexasSeville
11-06-05, 01:22 AM
The low oil pressure could be from a leak but more often is caused by gunk in the oil pump. Serious deposits of carbon in the engine are carried in the oil which will eventually lead to oil pump suction/discharge pressure problems.
Some NorthStar mechanics claim that filling the crankcase with 16qt of motor oil, then revving the engine to 6K a few times will help to seat the lower seals and dislodge sediment build up in the sump. Then drain the crankcase, and refill to the proper level.
Do I recommend it? Absolutely not! It is here for you to try, but if you value your Cadillac, I would not attempt it on one of mine.
You were not specific, if the oil level was low, or if just the pressure is low. In either case there is a problem that must be addressed immediately.
Ranger
11-06-05, 01:40 PM
Being a qt. low will not set off any bells and whistles. The Check Oil Level message won't even come on til you are 2 qts. low. Since it sat for 2 yrs (valves and switches may be a little sluggish and sticky), and the light has not come back on again, I'd wait and see what happens. If it returns, then I'd look at the oil pressure switch. it is on the oil filter adapter.
frankmarks05
11-06-05, 03:45 PM
thanks ill do that...
zonie77
11-06-05, 06:01 PM
If it sat for 2yrs are you sure the oil has been recently changed?
Did you do it or the dealer? What oil was used?
tremor12
11-06-05, 06:23 PM
Probably a bad oil pressure sender. Cheap and easy to replace during an oil change...
frankmarks05
11-07-05, 01:03 AM
i had it do today dove it abouth 50 miles nutting came up on the cluster
i used 5w30 oil i think the man said allmost 8 qt's
auroradude
11-07-05, 01:43 AM
Sitting for 2 years is extremely bad, especially if it was only started up to move or something like that. Better off not even starting it if your going to move the ****. I wouldnt have bought the vehicle if theyd have told me that..
Anyway i had the low oil pressure message come on in 105 degree weather one time. It was when i was using Mobil 1 5w-30. My engine has serious leaks that have gotten worse over time. It blows oil out all over the side of the engine when driving. I mean the entire block is just covered in gunk and sludge, its gross.
But anyway, It got as low as like 2.5 quarts remaining in the crankcase, and it actually shut off on its own. I thought I locked up the motor, but it wouldnt restart until i filled it back up to 7 quarts. Good system.
ewill3rd
11-07-05, 06:56 AM
Check the oil level and monitor it for a repeat failure.
(as you are doing)
Sometimes the oil pressure switch will go bad causing the light to come on. Just to be sure you might change it, that way if the light comes back on you will know you actually have a problem.
Low oil level can cause this to happen but the oil would have to be really, really low.
If that message comes on, pull the car over and shut it off, don't run it until you know it's okay. No sense in taking a chance ripping all the bearings out of your car, unless you just really want to buy a new engine.
I'd replace the oil pressure sensor just to be sure though.
zonie77
11-07-05, 11:07 AM
Most new engine designs use lower pressure than old designs. Changing oil should have been done before you drove it off the dealers lot, or as SOON as you could.
If it's good with fresh oil it should be OK.
CadillacSTS42005
11-07-05, 11:43 AM
i had that light come on after having my oil pressure light pulse for about 10 minutes. When that message came on the oil light came on steady. Babyed it the 1 more minute home. HAD AN OIL TRAIL THE WHOLE WAY!!!! Filled it up with 9 quarts drove it to the dealer (about 10 miles away.) Pulled in went inside and by the time i told them what happened and they moved the car onto the lift a puddle the size of your head was already there. They lifted it and discovered one of my main oil pressure lines came loose. Tightened it up filled it with oil and started to drive it home. Hit the pedal and as soon as youd hit 3000 rpm the engine would knock BAD. Took it right back. Thing busted a rod was in the shop for 3 weeks while they put in a "new" (from a 96 STS with 36k on it) Northstar.
In submation DONT *** AROUND WITH LOW OIL PRESSURE!!! Take it back now and have it looked at and have them run the codes. If that light came on theres a code in the DIC stateing why.
Eldyfig
11-07-05, 12:56 PM
You were at low idle when this message came up and the chime sounded, correct? The north*s have considerably low oil pressure at idle. Like Ranger and ewill and maybe others stated, you oil pressure switch might need changing. I experienced the same thing almost a year ago. I was a only a quart low. I normally use 10w30. I dropped a quart of 10w40 in and haven't had a problem since.
frankmarks05
11-08-05, 01:01 AM
You were at low idle when this message came up and the chime sounded, correct? The north*s have considerably low oil pressure at idle. Like Ranger and ewill and maybe others stated, you oil pressure switch might need changing. I experienced the same thing almost a year ago. I was a only a quart low. I normally use 10w30. I dropped a quart of 10w40 in and haven't had a problem since. yes i was i just changed the oil thay put 5 w 30 in it ill try this and see what it will do next oil change i will put 10 w 40 in it .....
zonie77
11-08-05, 05:46 PM
I'd recommend 10-30. You may want to stay with 5-30 winter and try 10-30 summer.
You had old oil that may have had WATER in it from condensation. If it had been drained into a clean pan you might have seen it. A shop might not have noticed it if they used a lift and then poured it into their holding tank.
mcowden
11-08-05, 07:36 PM
You're on the right track I think. An old friend of ours used to say that if everything else had been done, i.e. harmonic balancer bolt tightened appropriately, pressure sending unit changed, etc., that using one of the heavy duty diesel oils such as Rotella, Delvac, or Delo in 15W-40 weight could be used to alleviate intermittent idle pressure light issues. More than one person came back here to say that cured their problem. Before you go that route, though, I would make sure all the other bases are covered. Another oil change to help eliminate any residual water perhaps, change the sending unit at the filter adapter, and check the harmonic balancer bolt torque.
frankmarks05
11-09-05, 11:11 AM
thanks guys for all your help i just got it back from service thay found a bad oil pressure switch and a little leak but the oil pressure is fine in the car ..
so it must have been the switch. thanks agine.....
Eldyfig
11-09-05, 10:17 PM
Thanks for posting back the solution. This will help others.
Don't become a stranger. You are part of a decent family of cadillac enthusiasts now.:cheers:
frankmarks05
11-10-05, 07:47 PM
well i drove the car for a day now no lights but still have a oil smell i looked under the car i have a small leak you guys have any quick fix to stop the leak without pulling the motor out?
zonie77
11-14-05, 11:34 AM
It depends where it is leaking. Find the leak first.
keep it fresh
11-28-05, 04:49 AM
i have the same problem on my 97 deville but my shyt aint leaking car runs fine wtf could it be it flashes then when i drive it goes off i stop it comes on it only comes on when car is warm
Patrick7997
11-28-05, 10:02 AM
Interesting thread....
Earlier in the post, 91TexasSeville reported filling the engine with 16 quarts and running it.... I have heard of this too.
I wouldn't do it, but I DO do something that I feel is just as effective.
Change the oil over & over until it's clean.
1. Change oil & filter
2. drive the car 100 miles or so ( I have a long commute, so this is real easy for me)
3. change the oil again.
4. repeat steps 2 & 3 2 or 3 times, or until the oil is coming out clean, or at least mostly clean.
If the engine is full of sludge, after a couple of changes, you will definitely see an improvement in the color/quality of your drain oil, and then you know you are making progress....
If I knew the car had been sitting for 2 years, I would DEFINITELY do this... also, try to DRIVE IT. Driving it is the best thing you can do.... These cars are wonderful marvels of thousands of moving parts... get them moving again!!
Anecdotal evidence: I work for a large Company. We obviously have a pile of company vehicles. The ones that are driven like crazy every day run forever. The ones that get parked in the back of the lot for a few months, and then reassigned to someone.... those are the ones with the troubles.
Not to say that your car is going to be nothing but trouble....no. I am NOT saying that. But, I would suggest the above procedure, and to drive it as much as you can for awhile.
Good luck.
Patrick7997
11-28-05, 10:09 AM
Slight addendum, sorry.
In the summer I use Mobil 1 10W30. In the winter, I use Mobil 1 5W30. I change every 3000 miles regardless of what the oil life index says.
For this repeated change process, however, I generally buy whatever is cheapest on sale at whatever big box store is running a sale. I personally use 5W30 for the repeated changing. I feel that the sludge will thicken things up in short order, and the whole point is to get things flowing again, so I think the thinner oil is the way to go, to try and suck out all the nasty stuff that's in there.
Good luck.
auroradude
11-29-05, 12:36 AM
Ummmm, instead of repeatdly changing oil like that (which does nothing btw), you could just try Auto-RX. This cleaned my engine pretty well and others in my aurora groupie. Of course, with my rediculous leaks, it didnt do as good as it WOULD have with new seals, but still. The others got the cleaning that I would have gotten.
www.auto-rx.com (http://www.auto-rx.com)
At least give it a freaking shot.
Patrick7997
11-30-05, 08:43 AM
"which does nothing, btw"??
Ahhh, put me down for "Disagree".
